2.0 turbo swap - Second Generation Forum
2.0 turbo swap
Saturday, August 06, 2011 2:35 AM
looking at swapping a 88 sunbird turbo engine into my 84 chevette. does a s-10 manual tranny from a 2.2l bolt up to this engine? can i run the engine without the factory computer by using megasquirt and a msd 6 btm ignition control unit? the msd box retards timing as boost pressure goes up.
Re: 2.0 turbo swap
Saturday, August 06, 2011 9:21 AM
The trans won't bolt up to the OHC 2.0. I don't see why you couldn't use that plan for management.
Re: 2.0 turbo swap
Saturday, August 06, 2011 10:32 AM
I thought the 2.0 and the 2.2 blocks were the same?
Re: 2.0 turbo swap
Saturday, September 03, 2011 4:31 PM
Nope, not the same blocks at all.
I think your best bet is to use the factory wiring and PCM to run it and mod it as needed. I have a whole sunbird turbo harness i dont need, cant remember if i had the pcm or not.
"Hondas are like tampons, every pussy has one!!!"
