 you are here: / home / forums / second generation
Saturday, May 18, 2013
Back again with another 3.1L stall issue.. - Second Generation Forum
Forum specific to the 1988 to 1994 J-cars.
Previous MessageNext Message
Wednesday, December 14, 2011 3:29 PM
Quick run down.. 1990 3.1L Z24 with 3 speed auto trans.
Starts up fine. Runs for maybe 8-10 minutes before stalling out in park. Will not restart for another 10-15 minutes.. then it's fine again. No codes are being thrown. Checked IAC and IAC housing. They are clean as a whistle. Unsure where to go from here..
BeardLife / Club Awesome Reject Blog
Advertisement
Upgrade to premium membership to remove this ad.
Re: Back again with another 3.1L stall issue..
Wednesday, December 14, 2011 5:13 PM
Fuel pump relay? A friends civic did this. That's all I can compair too.
Saturday, December 17, 2011 9:39 PM
Not saying it is not a fuel pump or relay BUT sounds more like a ignition module or coil going south.Just check your psi for the pump(41-47psi) if solid pump good,relay you could replace but,I am leaning more towards what I suggested.Just a thought before I myself run out of gas after working all day.
Monday, December 19, 2011 6:31 PM
Thanks guys!
I let her stall the other day and had someone crank it over while I held a plug wire.. No spark was created so I ordered an ICM.. Should be here soon and I will update this!
Monday, December 19, 2011 8:13 PM
I sure hope my suggestion works out for a nice running J soon for you.
Monday, December 19, 2011 9:01 PM
ICM sounds like it will do the trick.
Monday, December 19, 2011 9:55 PM
Definitely sounds like a faulty coil.
Sunday, January 15, 2012 9:30 AM
Replaced the ICM and issue happened again.
Pulled remote start module and problem is solved
I should have pulled the remote start right off the bat! Oh well. It's solved!
Sunday, January 15, 2012 8:52 PM
Nice glad you corrected the problem.That is ALL that matters.
Friday, January 20, 2012 5:51 AM
Note to self (and others): pull the aftermarket BS when diagnosing a car. :-)
All Rights Reserved
