 you are here: / home / forums / second generation
Wednesday, May 22, 2013
Can the timing be adjusted on a 1986 2.8? - Second Generation Forum
Forum specific to the 1988 to 1994 J-cars.
Previous MessageNext Message
Friday, March 30, 2012 2:36 PM
I have an 86 Cimarron and the previous owner replaced the distributor. He said the timing needed to be set. I cannot find the adjustment for it in the Chiltons or the Caddy service manual. They only reference the 87 and up motors. I know it is a 1st gen but most of them are 4cyl so I figured I would ask the question here.
Thanks, John
https://lh4.googleusercontent.com/-hZ54_qttEVU/UN5VqiOXLdI/AAAAAAAAEsQ/Vk1rxn8r2Cs/s576/1.JPG
Advertisement
Upgrade to premium membership to remove this ad.
Re: Can the timing be adjusted on a 1986 2.8?
Saturday, March 31, 2012 2:38 PM
Actually what I cannot find is the single brown wire with black stripes to put the dist in the timing mode. I can see a brown wire with black stripes but is in the harness and not by itself. I set the timing without disconnecting the harness. Will the timing be set correctly? It seems to run a little better and was off the timing mark by about 1 inch before and now it is right on.
All Rights Reserved
