Squeak When Turning - Suspension and Brake Forum
Squeak When Turning
Tuesday, November 24, 2009 3:54 PM
It just started today. When I turn the steering wheel, I hear a squeaking noise. It's more obvious when I'm going slower. It sounds almost the tire rubbing, but it's not that. It sounds like it's something about to go, or has already gone lol. Also, in the last couple days, I feel a slight pulse in the wheels when driving. The faster I go, the faster the pulse. I don't know if the two are related. I haven't had a chance to dig around to find the problem. If anyone can help me figure it out, it would be much appreciated!
Thanks
* * BIG FOR SALE POST * *
Re: Squeak When Turning
Friday, November 27, 2009 6:36 PM
bump
Friday, November 27, 2009 6:55 PM
Are you turning the wheel all the way and holding it tight? If so that your pump screaming for help...
Could be a loose belt, low fluid, brakes, wheel bearing... lots of things.
Friday, November 27, 2009 8:02 PM
I'm just barely turning it, after I turn it past a certain point, the sound goes away. I had in mind either steering fluid or wheel bearings. I would prefer it not be the bearings though lol. Is there a way I could test the bearings specifically?
Friday, November 27, 2009 8:19 PM
Wheel bearing.
Friday, November 27, 2009 8:25 PM
^^ Holy f'ing huge sig pic...
You could jack the front end up, put it in nuetral, then spin the wheels by hand and listen. Also grab the wheels with your hands and wiggle the wheels left and right, and up and down for play or to much movement. A little play is fine...
Saturday, November 28, 2009 2:21 PM
EcoCav [DesertTuners.com wrote:]^^ Holy f'ing huge sig pic...
It's fixed.
It's fixed.
Monday, November 30, 2009 3:13 PM
Thanks guys, I'll look into it some time this week.
