k member swap??/ - Suspension and Brake Forum
k member swap??/
Sunday, March 11, 2012 6:31 PM
wasnt sure where to post thissry...want to take k member from 01 z24 and put on my 99....the 01 is wrecked and i am swapping motor and tranny already....r they the same?/will it wrk?thanks....
Re: k member swap??/
Sunday, March 11, 2012 7:26 PM
yeah it will work, how was it wrecked? Make sure its not tweaked.
Monday, March 12, 2012 6:35 AM
AFAIK, the only ones that may run into an issue are the people with 95-02 2.2/2200 engines and 03+ subframes, because the clearance for the OHV exhaust was removed in 03. Other than that, there should be no problems swapping any 95-05 subframe.
Monday, March 12, 2012 7:02 PM
hes right they did away with the hump and did a solid brace with holes in it.
Monday, March 12, 2012 7:19 PM
it was hit in passenger side door....i guess i cld take inside measurements front and bck ???and compare to my 99???n e other way?mines jst really rusted and wld rather use the 01..gon bead blast either way...thanks for the input
Monday, March 12, 2012 7:47 PM
i fit was a door hit you should be fine.
