Saturn rear disc swap help - Suspension and Brake Forum
Tuesday, June 05, 2012 9:34 AM
What is the trick to hook this ebrake cable into the saturn caliper?
Re: Saturn rear disc swap help
Tuesday, June 05, 2012 8:48 PM
I had this issue when i put mine on and did a write up... they were holding back the information for a while... but here it is... one side at a time grab the left/right cable at the splitter, with ebrake disengaged in car, pull the cable to the side of the car your working on so it has more slack, and you can pop it right in. then do the same on the other side, they will even themselves back out once they are on, they are just a pain to do it when you don't know how. but they slide right in, just pull till you have plenty of slack and pressure off the end spring...
Friday, June 08, 2012 7:15 PM
cool. i appreciate the help.
Wednesday, June 13, 2012 10:43 PM
I hooked up the e-brake cable first, then attached the bracket to the caliper. It took me a min to figure out, but when you are up in there, you'll see what I mean.
<a href="http://s7.photobucket.com/albums/y262/viewsonic17ps/?action=view&current=P5030243.jpg" target="_blank"><img src="http://i7.photobucket.com/albums/y262/viewsonic17ps/P5030243.jpg" border="0" alt="Photobucket"></a>
Wednesday, June 13, 2012 10:45 PM
