For those running Wilwood front big brakes... - Suspension and Brake Forum
Tuesday, April 02, 2013 11:46 AM
Has anyone swapped the over to banjo fittings at the caliper?
I ask because I am not happy with the current way Wilwood attaches their stainless lines to the caliper.
BeardLife / Club Awesome Reject Blog
Re: For those running Wilwood front big brakes...
Tuesday, April 02, 2013 12:47 PM
Why are you not happy? And why do you want to change it?
Tuesday, April 02, 2013 12:54 PM
I am doing this right now, got the Goodridge stainless lines. Although I am not using a bolt on Wilwood kit right now... Although I would have to think the brake line hole would be the same.
Tuesday, April 02, 2013 2:22 PM
I've had one of their 45 degree fittings loosen up on me a few seasons ago causing a mess of brake fluid on my wheels and potentially causing a HUGE leak. Plus when they are tightened down the direction of the fitting cannot be controlled. I want to choose where my brake lines are aimed.
According to the Wilwood kit the calipers provided for our J kits uses a 1/8-27 NPT fitting in the caliper and a -3 line. I have yet to find a banjo bolt in 1/8 npt thread.
Wilwood brake line kit.
Tuesday, April 02, 2013 7:03 PM
Probably because banjos are usually straight threads and not NPT AFAIK.
You should be cool using a normal 1/8-27 banjo bolt since NPT threaded holes are just normal straight threads. Its generally the part that threads in that has the taper that seals in the fluids. Thats if you can actually find an 1/8-27 banjo bolt. I didnt really see anything around that size.
Your only option might be the ole drill and tap.
On second thought an 1/8-27 would be the same as a #5-27 bolt.
Edited 3 time(s). Last edited Tuesday, April 02, 2013 7:25 PM
Tuesday, April 02, 2013 7:21 PM
My wilwoods from mark have straight fittings. But its not the willwoob box kit.
Wednesday, April 03, 2013 5:28 AM
cant use a washer to readjust the direction. loctite?
whats wilwood have to say on the subject?
It's nice to be injected but I love being blown.
Wednesday, April 03, 2013 5:58 AM
I just don't feel that would be the solution I am after. I haven't contacted Wilwood yet. I may do that soon.
I know Todd Miller did this swap successfully but the list he gave me is long gone. I may PM him as well.
Wednesday, April 03, 2013 7:11 PM
why not just buy a straight fitting like i mentioned?
Thursday, April 04, 2013 6:27 AM
Ordered a set. I may get some shorter lines made as well.
Wilwood provides 8 foot long brake lines for this setup. (slight exaggeration).
Wednesday, April 10, 2013 9:37 AM
Problem solved.
For some odd reason my current lines are 18" long and after checking the Wilwood website my lines should only be 13". I ordered a set of lines.
Wednesday, April 10, 2013 12:40 PM
well wtf.. u get 18" lines and safety wire bolts?!!?!? LOL
Wednesday, April 10, 2013 1:07 PM
Dude I have no clue! lol
I recall ordering the lines through Karo way back when I got the kit.
