Has anyone ever tubbed the wheelwells to lay? - Suspension and Brake Forum
Monday, February 07, 2005 1:26 PM
Well just as it sayes, has anyone ever tubbed the wheelwells out to lay on a larger rim/tire combo? The back is the easy part, cut it out and fit in a trailer fender tub in. The front is what has me wondering, I have never seen a fwd tubbed out to lay on a larger tire. Im sure you could do it, i dont see why not.... the unibody structure would just have to reinforced where the metal was cut out.
Anyone have any pics of this?
Re: Has anyone ever tubbed the wheelwells to lay?
Monday, February 07, 2005 1:35 PM
i think what they do is get a wide front end. look at karo's slowfire. hes got a one piece front end which is way wider than stock.
Land Pirates sail the open roads
DISCLAIMER: If anything I say offends you, I don't care..wear a helmet. Also, the information
I post is what I know to the best of my knowledge. If I am wrong, please correct me so that
others as well as myself may learn.
Premium sinc 6-17-04
Monday, February 07, 2005 3:57 PM
i wanna know to..i was thinkin of doing it also
Monday, February 07, 2005 7:39 PM
Land Pirate---That wide front end has nothing to do with ruinning a taller tire and still being able to lay out.
THe problem that the J has up front is how the top of the tire rest on the frame when the air is let out of the bags or rods.
Now I beat the crap out of mine and I can drop down and not rub with a 215/45-17.
But if you want to run 19" rims your going to need more room.
Ive seen some front wheel drives that simply had the bulky inner fenders removed and in there place had some tubing welding in to mount the top of the strut to.
98layin frame--Get to cuttin mang. I want to see it. Ive about givin up on my car. I simply dont care anymore. THe bags may even be coming off soon.
I am all that is man
Tuesday, February 08, 2005 5:26 AM
Well if your taking your bags off.... any chance you would want to sell the front struts cheap? Please......
Tuesday, February 08, 2005 5:33 AM
ohhh.... and what about the strut assembly itself? Will the strut assembly be able to compress enough to still layout on the taller tire? I dont want to go and cut everything out for clearence with the tire, just to have the strut bottom out on itself before the car is able to layout.
ESB - when your laidout, and your tire is touching the inner fender.... do you know if the strut has any more travel left in it or no?
Tuesday, February 08, 2005 6:17 AM
ESB you should have remembered this post
http://www.j-body.org/forums/read.php?f=3&i=52917&t=52627&arch=1#52917
all the time
Thursday, February 10, 2005 11:47 AM
thats pretty badass... now thats what im talkin about. Forget using a bodykit to get low I was allready thinking about how i could bodydrop her car, but one..... i didnt want to get in to modifing the whole front suspenion with the upper strut mounts and all, and second its her daily driver... and theres no way in hell shes gettin my truck to drive around while im working on her car.
Im guessing no one has any pics of a tubbed out cavy huh? guess i just gota go at it blind... hey i got my truck down... i'm sure ill make it through
Thursday, February 10, 2005 5:24 PM
Well first of all. THat laid out cavy DOES NOT use the same front struts that are made for our cars. Because the ones made for us will not compress low enough. Ive talked witht he guy a couple times when I had to order some parts. It has sleeve type bag struts up front now.
RIght now Ive cut and beat up enough crap that my front will drop down and the tires DO NOT touch the frame. SO if you cut out more stuff to fit a taller tire all you will do is actualy raise the car up some because the strut is bottomed out already.
You would need to raise the upper strut mount location.
WHich means cutting a hole in the hood (ive already got big nipples on mine) or molding some bubbles in it.
The only J ive seen lay the front on the ground had 205/40-17s or something along those lines. To tiny IMO. Looked funny.
And I cant make up my mind about removing my bags. One day I want them the next I dont. Maybe once I get a truck and its ready to get bagged I may take them off.
Thursday, February 10, 2005 5:34 PM
<img src="http://img224.exs.cx/img224/6148/cav14ve.jpg" width="360" alt="Image Hosted by ImageShack.us" />
<img src="http://img224.exs.cx/img224/8223/cav29nb.jpg" width="360" alt="Image Hosted by ImageShack.us" />
In that pick ^^ you can see the sleeve bags up front.
And some more rear shots
<img src="http://img224.exs.cx/img224/5666/cav31ez.jpg" width="360" alt="Image Hosted by ImageShack.us" />
<img src="http://img224.exs.cx/img224/4654/dscf00121wb.jpg" width="640" alt="Image Hosted by ImageShack.us" />
Friday, February 11, 2005 6:15 AM
yeah i see that, he removed the entire front strut purch, and is now using a shock wave for the lift.. nice See thats what im talking about, i dont want to have to remove that uppper strut mount. I just want to be able to get the car as low as possible and still have some clearance... so it can be driven slammed and not be rubbing the tires.
Those pics also show that he did cut the factory structure above the wheels, but it looks like he just left it all cut out since the tubular frame is whats holding the front of the car up and not those towers. I would just have to box them back in for strenght. the setup he has in the rear is considered a canti lever setup.... thats a nice simple setup that gets a good amount of lift im sure.
Friday, February 11, 2005 2:31 PM
I can roll all the way down up front but the tires still rub the lips of the fenders.
My rims press the fenders out every time i drop down.
<a href="http://img110.exs.cx/my.php?loc=img110&image=pict00114dm.jpg" target="_blank"><img src="http://img110.exs.cx/img110/5206/pict00114dm.th.jpg" border="0" /></a>
Monday, February 14, 2005 6:58 AM
hey esb... what is that pic of? that the front fender edge rolled? or the rear lip rolled?
anyone else have a pic of some tubbed out cavy's?
Monday, February 14, 2005 4:24 PM
THats my front fender. And you can see whats rubbing.
I would pull it out but its already bulging out alot when dropped.
Tuesday, February 15, 2005 8:01 PM
Check out this link. This guy has done a lot of work. its on juice so that will make for it to go lower. But he still did a lot of work to front end. Might try getting a hold of him and see what hey says.
CLICKY
bump
Wednesday, February 16, 2005 6:48 AM
thats pretty sweet. i like how he did the engine bay, but not sure if the sheet metal on each side is just for looks, or if he removed most of the structure under there for clearence though...
Wednesday, February 16, 2005 7:06 AM
I'm not real sure what was done. I sent him a message a while back asking him but I didn't get a responce. I would love to know more about it though.
