coil over question - Suspension and Brake Forum
coil over question
Tuesday, March 01, 2005 5:20 PM
does the spring of a coil over (let say the ground control) is the same as a normal spring (sportline for the G/C if i go with the color) ????
Re: coil over question
Tuesday, March 01, 2005 5:34 PM
different. the coilover springs have a much higher spring rate. also, the sportlines and many lowering springs have progressive rates, coilover springs have linear spring rates. but eibach does make the springs for the ground control coils. hope that helps.
this is my sig
Tuesday, March 01, 2005 9:00 PM
ok
nice to know
caus i would just have bought a sleeve set for like an older nova or something and dropped the front end just a bit more than the rear
now i just will buy normal springs!
Wednesday, March 02, 2005 5:53 AM
The springs are also very different in size. Coilover springs tend to be only slightly bigger than a soda can. The two are certainly not interchangable.
