Suspension - Suspension and Brake Forum
Suspension
Sunday, March 20, 2005 6:56 PM
Alright was curious if anyone has had a kyb AGX with either ground control coilovers or the Rk Sport coilover system? OR has anyone tried the above coilovers with the Tokico HP? If so what are your thoughts? or anyone that knows anything about these 2 strut and coilover setup any info would be great. Thanks
<img src="http://img.photobucket.com/albums/v212/ceanern/entrappedfury.jpg">
Re: Suspension
Sunday, March 20, 2005 6:58 PM
If you're in the market, the only dampers I recommend for coilovers are the Konis because they've been proven to work.
It's worth saving a bit extra for.
Re: Suspension
Monday, March 21, 2005 7:32 AM
yeah. mainly the coilovers are goin to be up unless I'm at a show with the car. cause PA roads SUCK!
Re: Suspension
Monday, March 21, 2005 7:40 AM
i can say this much. The spring rate are higher on coil over so height is not a real factor as to how long they would last. Yes they will last longer if higher but the spring rate are still higher. Plus with the ground contol or rk the highest setting is still about 1" lower than stock.
all the time
Re: Suspension
Tuesday, March 22, 2005 4:53 PM
Aside from Air ride. What coilovers would hold up longer? Also has anyone used the Tokico HP Struts? The roads are good but bad. Mostly really Hilly. and the occasional Pot Holes.
Re: Suspension
Tuesday, March 22, 2005 6:10 PM
the coilover wont be the thing failing if your talking about sleves. It would be the shocks you have or buy if they arnt designed for it. I recomend the koni shocks with any coilover sleve or just buy the full coilovers that are designed that way. Rksports full, tien, or gravannas new kit are some suggestions.
98' Pontiac Sunfire SE
Re: Suspension
Wednesday, March 23, 2005 5:41 AM
Well that sucks. Guess after the lambos it is time to start savin' up for both a paint job and coilovers.
