ok.... been a while.. whats wrong - Suspension and Brake Forum
Monday, March 28, 2005 1:43 PM
OK.... here we go again. I'm finally getting around to taking the pro streets off my sisters car and putting stock stuff back on. I swap out fully assembled strut, spring, and mounts and go on to the next corner. I've checked every bolt and lug nut and for some reason when i'm driving it feels awful. I know it needs an alignment now but this is scary to even drive to the bottom of the road to the gas station. I have no noises or anything, but it just seems the steering is way off sorta the way you would feel if you had a really low tire or something. I hadn't driven the car in months so i checked tire pressure and it was low and after putting air in the fronts it still looks low but is dead on. Bring on the advice.
<img src="http://www.j-body.org/registry/agrosk8r5/personal_pic.jpg">
For Sale: rk pro street coilovers
Re: ok.... been a while.. whats wrong
Tuesday, March 29, 2005 7:25 PM
is it possible that the stock struts are blown? and that going from the tight modified suspension to the stock stuff w/o an alignment is dramatic enough that it feels really sloppy? get the alignment, maybe have someone follow you to the garage. i don't know how far you will have to go for a shop, its been awhile since I was home, good luck man.
Tuesday, March 29, 2005 7:48 PM
i'd say get the alighnment done.. prolly it, also the tech would most likely notice if something isn't installed right...
