rotor will not slide off - Suspension and Brake Forum
Friday, April 22, 2005 9:29 AM
I took off the caliper, and the rotor will not slide off. I assume it's rusted on there and I sprayed penetrating oil in there, but it still won't come off. I already tried using a rubber mallet, no dice. Any suggestions?
hp is overrated...it's all about the g's
Re: rotor will not slide off
Friday, April 22, 2005 9:34 AM
if you're replacing them, get a bigger hammer
if you want to put them back on, i have no suggestions
Friday, April 22, 2005 9:38 AM
Yeah, beat the hell out of em
Friday, April 22, 2005 9:39 AM
that's the thing, i'm just replacing a stripped lug stud. I will be putting the rotor back on...
Friday, April 22, 2005 9:41 AM
It should come right off... I had to replace a broken stud a few months back.... Try hitting it on the back side with your mallet, and switch which sides you are hitting it on... it should jar it loose.
Rob
Sold 2/2/05
Friday, April 22, 2005 9:54 AM
uhhhh take the tire off?
jk
Never had a rotor stick on. I say get a thin chisel and lightly tap it around the hub where the rotor is making contact....maybe that will break the rust seal. Otherwise keep hitting it with a rubber hammer...or a plastic dead blow hammer.
-da chinchilla
<img src="http://registry.gmenthusiast.com/images/jiggamon/avatar15569_2.gif">
Friday, April 22, 2005 10:09 AM
got it off...thanks for the input
