curious - Third Generation Forum
curious
Thursday, May 26, 2005 12:23 PM
What is the cheapest preformance modification that you can do to a 2.2L and give it a noticable amount of horsepower?
Re: curious
Thursday, May 26, 2005 1:14 PM
Nitrous
Re: curious
Thursday, June 02, 2005 8:27 AM
nitrous will give you the biggest gain for your dollar, but power is not cheap. We all wish it was!
New sig in the works
Re: curious
Saturday, June 04, 2005 1:35 PM
header or motor mounts probably...
Re: curious
Saturday, June 04, 2005 3:40 PM
im dumb but how do motor mounts help i always wondered that?
Re: curious
Saturday, June 04, 2005 4:45 PM
motor mounts; the mounts that are stock have a little play in them because they are made of a soft rubber compound. new aftermarket ones will have either a stiffrer more riddged compound or a strait piece of metal in stead of soft rubber, depending if you buy a upper or lower bracket. the harder compound or the metal bracket will put more torque to your tires than in motor sway, just to warn you the upper mounts make your dash SHAKE like crazy, when in idle.
" K bye!! "
Re: curious
Sunday, June 05, 2005 6:06 PM
thanks
got a third place with my 95 cavy in my first car show
http://www.cardomain.com/ride/664325
Re: curious
Sunday, June 05, 2005 6:29 PM
I've seen nitrous up to $6 per Lb. aparently in some area's it dips to $4. in the long run, it's most likely cheaper to go with a turbo, but that is a very long run.
CAR GODS MADE THE 1.6 SOHC TO MAKE US 2.2 OHV GUYS FEEL BETTER.
Re: curious
Sunday, June 05, 2005 9:17 PM
Easy a peach can to ask how you need to think!!! stock intake tube and cone filter fill in the blank
Its not my cavaliers fault, its a taco burner!
Re: curious
Sunday, June 05, 2005 9:56 PM
greenspeed wrote:stock intake tube and cone filter fill in the blank
I did that once. The car gods almost killed me. Dont do what Donny dont does. Donny dont has a stock intake tube with a cone filter.
-- The The One One --
<IMG SRC="http://registry.gmenthusiast.com/images/neo32843/personal_pic.gif">
Re: curious
Monday, June 06, 2005 6:34 PM
yah its not pretty but i gets the job done and a sweet note and hp gain!
