queston about wirinig - Third Generation Forum
Monday, June 06, 2005 7:05 PM
ok does anyone know if the gauge cluster gets the signal forr the speedo n thhe odometer from the vss or does the signal get proccessed by the ecu before the signal gets to the cluster
http://registry.gmenthusiast.com/images/sinrocker/0061-2.JPG
check it
2000 Cav 4speed auto
rsm vortec v9 blower 8 psi, venom 270cc injectors, front rk strut bar,rear vibrant strut bar, jdm
floor bar stablizer, altezz tails, rsm ligthened crank pulley, upper/lower poly engine mounts,
msdingition coil packs, b&m shift improver, cooltek oil cooler, kick ass stereo with sirius,
Re: queston about wirinig
Monday, June 06, 2005 7:06 PM
For the 2k+, it gets sent from the ECU to the BCM to the cluster.
Monday, June 06, 2005 8:29 PM
i wonder if the ecu leaves the signal unchanged
check it
