Help on Replacing rear bumper - Third Generation Forum
Friday, June 10, 2005 6:59 PM
I need to replace the rear bumper on my 2001 sunfire. I have a new one ready to be put on but I'm not sure how to do it. I was told it's easy and it just bolts on and off. Anyway, just wanted to check so I didn't screw something up. Thanks.
SUNJAZZ
Re: Help on Replacing rear bumper
Friday, June 10, 2005 8:16 PM
In the trunk you will have two bolts on each side . Remove those and you will see some fasteners when the trunk is popped that are located beside each tail light . Remove those as well . on the bottom side of the bumper you will see some more plastic fasteners . If you pull up on the center piece on these it will pop up then you can remove the plastic fasteners and be able to reuse them .
Only takes about 5 minutes to remove . If it seems like it is stuck , check before ripping it off there may be another fastener or bolt some place you may have forgot about .
<a href="http://users.adelphia.net/~rdbryant1/index.html.html"><img src="http://registry.gmenthusiast.com/images/mrgoodwrench/personal_pic.jpg" border=4></a>
Saturday, June 11, 2005 5:22 PM
Also...
Cavaliers have 2x 10mm bolts in each rear wheel well, that go into a plastic support piece bolted to the inside of the bumper. That's where the two bolts on the inside of the quarter panel also screw down into..
I don't know if Sunfire is the same.. but I imagine that it probably is.
...j
<a href="http://www.lenkorules.com/"><img src="http://s93165229.onlinehome.us/images/zm/sig/LRDCsig3.jpg"></a>
