water in car with AC on - Third Generation Forum
Wednesday, August 03, 2005 5:07 PM
I just had my ac charged and when its on, I get a little bit of water in the passanger side front floor just behind the dash. I do notice the water dripping underneath the car when the ac is on, so I know the drain isn't clogged. I can't find a service manual anywhere for a 97 z24, but I want to address the leaking water. Can I fix the leak inside the car or am I going to have to go under the car? Any help would be appreciated. Thanks
69 Camaro 350, ST-10 4speed, Centerforce DF, Full Hotchkis suspension, flowmasters, MSD ignition, Baer brakes
96 Camaro RS Hotchkis shock tower brace, subframe connectors, trailer arms, panhord bar, and sway bars, power slot rotors, msd igintion, K@N FIPK.
97 Cavalier Z24 bone stock
Re: water in car with AC on
Wednesday, August 03, 2005 6:31 PM
the drain hose is probably cracked or split and is letting some water drain out normally and some drain into the car. judging by the mods on your camaros i'm assuming you know the water isn't actually antifreeze.
I would have wrote you a poem, but I couldn't find anything that rhymed with F@#K OFF!
