What's needed to swap an LD9 into a 1995 Z24? - Third Generation Forum
Monday, August 22, 2005 8:04 PM
OK I am looking at possibly buying a 5-speed '95 Z24 with a dead engine. I figured an LD9 would drop right into this car and bolt up to the tranny, but I have been told otherwise. Is that true? I thought that the only difference between the LD9 and 2.3L was the displacement. I mean I figured I would need the computer from the LD9, but was hoping everything else would be interchangeable.
Engine swap gurus help me!
Rob
Sold 2/2/05
Re: What's needed to swap an LD9 into a 1995 Z24?
Monday, August 22, 2005 10:19 PM
ok..i come across thie question every so often...first of all an ld9 will "bolt up" but the computer wont work...second..ITS A 95 Z24!! forget the ld9 and drop a HighOutput quad 4 in there !! itll bolt right up to the tranny, to the mounts, and even your ecu will work without any modification!! if you can get the car cheap consider yourself lucky...buy it..sale the parts off the junk engine that others need( like the throttle body and intake cam) and find yourself a good HO quad and never look back. im sure everyone will agree with me
"Freedom 'ought to have its limits"-George W. Bush may 31 1999 (who voted for this idiot?)
Tuesday, August 23, 2005 1:49 AM
I agree with scott except for 1 thing, the ecm. The ecm will work with the 2.4 engine.
You need a 96-98 2.4 to work properly. since it's OBDI, you don't need to use the cam sensor and EGR. Everything else should be pretty close to the same thing. Use the 95 sensor on the 2.4 engine and it will work.
Gilles
2.3 Ho
Tuesday, August 23, 2005 2:30 AM
i'd stick with the 2.3l. get yourself a HO.
SO EVERYTHING!
Tuesday, August 23, 2005 5:31 AM
Just wondering, I have the '95 Z24 2.3 auto. Is it easy to swap to the H.O. or the 2.4 and make it a manual? Also, is this OBD1 or 2 that I have? I thought I read somewhere that the '95's were OBD 2?
'95 Black Z24 - Stock with airbox removed
'99 Black GTP - CTPT61 @16psi, I/C, 94 oct, W/Meth,
TC, S/kit, 3.29, Cut-out, Cat Back, Magnaflow's,
GR2's, Eibach's, GMMP FSB, FBod Brakes, Cer Pads,
SS lines, C/D Discs, 17" Comp G's
12.63@118mph on Comp TA's!
Tuesday, August 23, 2005 6:32 AM
scott trent wrote:forget the ld9 and drop a HighOutput quad 4 in there!!
Yeah but how much does a Quad 4 cost, and where do I find one? I'm looking to make this pretty much a beater car, and only put about a grand into it. (including car and replacement engine for it)
Rob
Sold 2/2/05
Tuesday, August 23, 2005 9:15 AM
if its a manuel its a obd1 if its an auto its a obd 2
best bet is ebay or a junk yard..i seem to have no problem finding one for under 500 so just look around www.car-part.com is your friend
Tuesday, August 23, 2005 9:36 AM
Hmm well I can't seem to find any in my area other than two which each have like 90,000+ miles on them.
I don't really care about this car going fast anyway since I have my Goat for that . I'm just looking for something to cruise to and from my g/f's college since I don't want to rack up miles on my GTO and my truck gets crappy gas mileage when I go 70+ mph.
Plus I have a soft spot in my heart for the LD9... it was the engine in my first car.
Rob
Sold 2/2/05
Tuesday, August 23, 2005 10:47 AM
plus you dont want a quad4 or ld9, they stopped making them for a reason. they ended up being crap for reliability.
ld9 is ur best choice if ur buying a used engine, in terms of chance for lower milage already on it.
unless ur building it up, ld9 is prbly best
http://www.cardomain.com/memberpage/618295
Tuesday, August 23, 2005 11:20 AM
trdcelica90 wrote:plus you dont want a quad4 or ld9, they stopped making them for a reason. they ended up being crap for reliability.
WTF? They stopped making them because a better engine was developed. There are plenty of reliable Quads and TC's out there.. and many of us that build them up without reliability issues either. As long as you take care of it, it will take care of you.
By your argument, the Celica was ended for a reason too... crap for reliability? I don't think so.
Choose your words carefully
<a href="http://www.lenkorules.com/"><img src="http://members.shaw.ca/jlenko/sig/redsig.jpg"></a>
Tuesday, August 23, 2005 11:30 AM
a very uninformed comment....not to mention a quad is what came with his car and will be easiest to put back in......
but if your set on a ld9 i wish you the best of luck and hope it works out for you
but just for research sake i found a w41 quad (thats 190 hp stock) for 600 something with only 70k on it...but im sure i can find you a LO quad for much less..and thats what came stock in your car
Thursday, August 25, 2005 9:39 AM
u moron.. they dont make cavaliers either anymore.. lol wut r u saying .. 111k Miles on my LD9 and i drive the hell out of it.. no problems
Sunday, September 04, 2005 6:46 AM
hey scott that w41 you found, would you be ablw to find out how much for the intake mani tb and cams would be ????
Sunday, September 04, 2005 8:31 AM
they said they wernt willing to break apart a working shelf engine for parts..only bone yard engins will they do that with ..losers haha.....but i can get you new w41 cams for 350 and you should be able to get a intake mani and TB for pretty cheap..there all over ebay adn the w41s are the same as the HOs
