 you are here: / home / forum
Friday, November 20, 2009
2000-2002 Wiring harness question - Third Generation Forum
Forum specific to the 1995 and newer J-cars.
Go To TopSearchOptionsRulesHelp
Previous MessageNext Message
Monday, October 26, 2009 5:25 PM
Web PageAOL IMMSN MessengerPhoto
Just as it states I have an 01 5spd and the computer is in the wheel well.. It needed a new engine harness so the one I got has the computer that mounts on the strut tower like the eco's do so my question can I use this computer or not.. Even though it did come off an 01 also.. Thanx alot
http://i15.photobucket.com/albums/a381/maxxracer23/ModdinArtSignature.gif[/IMG]
Advertisement
Upgrade to premium membership to remove this ad.
Re: 2000-2002 Wiring harness question
Monday, October 26, 2009 6:35 PM
No you can not use that computer.
http://WWW.AZGMPERFORMANCE.COM
Monday, October 26, 2009 6:42 PM
Tuesday, October 27, 2009 4:53 PM
Web Page
umm not you can use that harness but you have to use the PCM for that harness your computer wont plug into it so get an 01 computer and plug it in
Tuesday, October 27, 2009 7:49 PM
i do have the pcm from the car that the harness came from.. i just didnt know if it would work or not but it will not show the correct mileage and stuff right.. i was just making sure that using a diff computer would be ok
Monday, November 02, 2009 12:35 AM
MSN MessengerPhoto
I've never seen a 2001 with the computer mounted at the strut tower... and I've seen a lot of J's...
You may have the harness from a newer Ecotec motor... if that is what was swapped into the older car. Or the harness from a 2200, but I'm pretty sure all the 2001's had the computer in the fenderwell, regardless of engine. (Someone correct me if I'm wrong here... I've never owned a 2200...)
Monday, November 02, 2009 11:11 AM
MSN MessengerPhoto
Add to that... mileage is stored in the BCM on the 2000-05 cars. Not the PCM... so you can swap the PCM without worrying about the mileage changing.
What engine is in your 2001? You don't have an 01 listed in your registry, so I'm confused.
Monday, November 02, 2009 7:27 PM
Web Page
01 2200s had strut mounted ones i think i think the 2.4 was the only one that didn't
i know 02 eco and 2200s did and 2.4 was still fender
Tuesday, November 03, 2009 9:44 AM
MSN MessengerPhoto
Well, I stand corrected then. I'll have to look closer at the car next time
Now that I think about it... I think the bracket was always there in the fender well... but with the engine & tranny pulled, the computer was likely pulled off the strut tower beforehand... which could be my source of confusion...
Tuesday, November 03, 2009 3:50 PM
Web Page
i know 02 2200 was on the strut tower for sure but i maybe 2nd guessing myself
Tuesday, November 03, 2009 4:03 PM
My 01 originally had the 2200 with the ecm in the fender well, not the strut tower. I thought that the echo's were the ones that had the ecm on the strut tower, starting in 02.
01 cav w/01 3400 gam gt 4t45e
Tuesday, November 03, 2009 5:47 PM
Late model 01 and 02 2200 had them on the strut tower like the ecos I got it all hooked up and everything but now the theft system light flashes it turns over fuel pump kicks on and everything but will not start.. Any ideas I hate 2200's lol
Tuesday, November 03, 2009 8:18 PM
well figured out it was the theft system since i changed the pcm's i had to reset the passcode and thanx to the faq section here on jbo it taut me how and within 25 min the car started thanx to all for your help..
