valve sticking? - Third Generation Forum
valve sticking?
Saturday, September 24, 2011 3:08 PM
"99 cav 2.2- used engine installed. runs rough, especially when cold. Guy at tire shop says it sounds like valve(s) sticking. I have a code for "misfire on #3". Is a compression check the only way to check this? While checking compression- do I need to disable the fuel injectors?
Re: valve sticking?
Sunday, September 25, 2011 3:03 AM
Yes disable the fuel injectors by pulling the fuse labeled PCM in the under hood fuse box.
Sponsored by: Kronos Performance
Re: valve sticking?
Sunday, September 25, 2011 7:50 AM
Thanks for the response!
