Is my alternator bad? Or is it something else? - Third Generation Forum
Wednesday, May 23, 2012 9:05 AM
I plugged in the aftermarket wire harness into the other harness that is already in the car.
The aftermarket harness has a door chime, which worked.
I wired in the head unit to the harness.
The head unit did nothing.
But, i did a bench test and wired the head unit to the battery and it worked then. so i know the head unit isn't faulty.
There is small black thing that holds the red ignition wire, yellow wire, and black ground wire. I was fiddling with it and it started clicking?
Also, there is a high pitched whining from i think the alternator, i havn't exactly check.
The car now starts up and dies instantly. Then i try a few more times to start it and eventually it makes a fast paced clicking sound.
Im wondering if i need a new alternator.
I can still push start the car and it works. But i cant start it regularly.
So im thinking its the alternator.
Re: Is my alternator bad? Or is it something else?
Thursday, May 24, 2012 10:09 AM
Thursday, May 24, 2012 7:31 PM
im sorry... but i don't understand not one word or even what you are trying to say here.
Thursday, May 24, 2012 8:48 PM
From wut i get it sounds like ur batt if u could start it and it runs ur alt is good but ur gonna kill it
And wtf did the radio have to do with it
*****BLAME IT ON THE ALCOHOL*****
Friday, May 25, 2012 4:18 PM
installing the radio, prolly with the vehicle running, and it killed the system.
does the car crank at all? and no, it's not your alt.
I need a new sig.
Saturday, May 26, 2012 1:16 PM
The alternator should whine while it's running.
Put your radio on an un-used AM radio station and listen to the static. Rev the engine. If you hear a noise through the AM and it changes with the speed of your engine, then the diodes are probably burned out in your alternator.
Doesn't sound to me like your alt. is bad though.
