Front lighting issues - Third Generation Forum
Sunday, July 01, 2012 2:38 PM
Picked up a 2000 Sunfire.. The Drivers side headlamp was dim. So I swapped out another harness from another 2000 sunfire.
Now none of the dirvers side lights work. BUT the four ways will flash.
GRRRRR!
This is what I have tried so far.
Checked for continuiety in the front harness. All GOOD
Checked for power from the C100 Plug from the car and there seems to be power.
Changed out the relay DRL
Any thoughts??
What we do in life Echoes in Eternity
Re: Front lighting issues
Friday, July 06, 2012 6:13 AM
LOL i just solved this issue on my 2000 cavalier....
check the fuse panel for the "LTHDL" fuse. it is more than likely blown, thats what mine was.
I choose the technology built for land speed records... not the technology built to save on emissions and gas mileage.
Thursday, July 12, 2012 11:11 AM
Thanks I will try that today. I will post back if it does or does not work and what else I try.
Friday, July 13, 2012 7:56 AM
That did not help. The front harness is good. I checked every wire for continuety. I swapped out the fuse for the LTHDL. Swapped out a relay at the DRL. Everything is good to the C100 Plug under the hood. The problem is from the C100 Plug back to the BCM/DRL.
Has anyone had to change a BCM? If someone has did you have to have anything else done after the swap?
This problem is annoying.
Friday, July 13, 2012 8:27 AM
I had the same problem a long time ago.Im going off my memory but i think it was a diode or something in the harness.Its in a little plastic box and its taped to the harness inside the wire loom.I forget the exact location but i got to it from under the hood.Its either near the 2 relays on the pass side or in the middle of the harness.Just pull the loom off and you should see it.hope this helps.
Peter
Gm Stage II W/2.79" Pulley
K&N Drop In Filter
Custom Magnaflow Dual Exhaust
Thursday, July 19, 2012 5:47 AM
is the ground on the harness under the battery tray connected?
Tuesday, August 28, 2012 8:56 PM
you have to cut split apart all the front lights harness sheathing coverings
and repair replace factory crappy splices
they are corroded and wires break
brown and blue wires ones
youll see exactly what mean once you yank the head light assemblies off the car and open up the harnesses
its a super common issue problem from factory on these cars i had to do this all on the 96 not too long ago
now all front lights work great
-96 cavalier 2.2 auto 143k miles
