car veering to the left - Third Generation Forum
Friday, August 24, 2012 8:47 AM
Hey guys my cav kinda veers to the left when I drive. As a matter of fact when I'm riding straight the wheel is turned slightly right to keep it straight and if I straighten the wheel then the car veers left fairly hard... What's going on and how can I fix it
Re: car veering to the left
Friday, August 24, 2012 8:56 AM
Possible tire issue???? Or maybe you hit a pot hole or your alignment is off.....
Erik Packard
Friday, August 24, 2012 12:09 PM
+1 It's called an alignment.
Friday, August 24, 2012 12:13 PM
perhaps the camber has shifted
dennis
Friday, August 24, 2012 2:34 PM
perhaps you had a tie rod end come loose.
Friday, August 24, 2012 4:08 PM
get the alignment checked probably a worn tie rod, very common if it does it only when accelerating then check the lower control arm front bolts
JBO since July 30, 2001
