zex dry kit with 2200 auto.. - Nitrous Oxide Forum
Sunday, July 31, 2005 4:55 PM
hey,
i got the dry zex kit with a NOS nozzle running about 45-50 shot .
I just got it installed. I was told that i will be safe using it with my acdelco plugs and stock fuel pump.
Its activated at full throttle opened, when i am at a starting line or whatnot, and its activated is it safe to do it like that, in the FAQ sticky it said its save as long the the car is lower RPM and it has room to increase and not to do it when i HIGHER gear going slow.. which is kinda impossible with the automatic.
any thoughts? am i safe using it off start? i did it few times and thats where i feel the most difference.
i am not planning to use it untill i go to the track or something ..
Re: zex dry kit with 2200 auto..
Monday, August 01, 2005 10:55 AM
its got a WOT switch so basically it only opens when your foot is on the floor.
That being said you are ok to spray whenever, launching you may hit traction issues, just get used to how much you can gun it how fast. As long as you dont max out RPMS as you are going and spraying, you are fine. Not sure what acdelco plugs u using, but alot use autolite 103s, or ngk tr6s for best results.
http://www.aplusperformance.com
http://www.modified-motorsports.com
Monday, August 01, 2005 2:16 PM
you will NOT be safe with the stock spark plugs. you MUST run a colder heat range, copper plug such as an autolite 103 or ngk tr6. stock platinum ac delcos turn into glow plugs under increased compression, which will cause catastrophic detonation (ie: chunks taken out of pistons and broken connecting rods)
also, premium octane (92 or higher) pump gas is needed to help avoid detonation.
