what are you using? - Nitrous Oxide Forum
what are you using?
Sunday, November 20, 2005 8:20 PM
for all you 2200 people out thier, what are you using to t off for fuel? and how are you doing it?
Re: what are you using?
Sunday, November 20, 2005 8:36 PM
well most people would just get a barbed connecter with a "tee" thread them together and splice in your fuel line ..........
just cut the rubber fuel line.... make sure your barbed connections are large enough... shove em in..... tie them off and connect the new "teed" off fuel line to the nitrous solnoid......
I believe thats how it's done ...
Lee
JDM Civic Hatch
Sunday, November 20, 2005 8:43 PM
ok, so thier are 3 points on the t.. the 2 ends of the t are barbed, and the one left pointing up need to be threaded right?,... is thier any fitting that people are commonly using?
Monday, November 21, 2005 1:34 PM
Daniel Boyd wrote:http://www.j-body.org/forums/read.php?f=39&i=11692&t=11692
check it.........
:claps:
N2O + Bolt-ons = 220Hp/250Tq
Coming Soon:HpTunersPro, EagleConnectingRods, WiescoPistons, 13sec2200
Wednesday, November 23, 2005 10:46 PM
Thursday, November 24, 2005 9:17 AM
either way your going to have to "T" the main fuel line. I chose aeromotive plumbing connectors and fittings for mine.
Monday, November 28, 2005 9:16 PM
well, im thinking about this setup.
FLARE UNION PRESSURE ADAPTER
STRAIGHT END
then using these to clamp
Monday, November 28, 2005 9:18 PM
the straight ends use a twist lok end, and can hold up to 250psi.. thats almost 5 times my fuel pressure.. im confident it will work, What do yuo all think?
Tuesday, November 29, 2005 7:40 AM
I do not see how it will t off.
Whenever I get my wet kit I plan to utilize the fuel rail somehow. I may tap it for the fuel line or put a gauge or even maybe put a fpss on it.
http://registry.gmenthusiast.com/images/importkilla32/Bullit.JPG
Tuesday, November 29, 2005 8:18 AM
well, you cut the rubber hose. those straight end's have barbed fitting to fit into the fuel lines. They twist, and lok, and then you tighten with the clamps. Then use the FLARE UNION PRESSURE ADAPTER to screw the to straight ends onto it. Now your fuel is reconected, but at the same time thier is a female standard bolt hole in the middle of the fitting. Then my fuelpressure saftey switch will screw in, or i can add another t and add a fuel guage, and my saftey switch
Tuesday, November 29, 2005 9:27 AM
I see what you mean but I still do not understand where you are going to attach the for the fuel Solenoid itself?
Tuesday, November 29, 2005 12:21 PM
i dont need to tap for fuel, Because im runing a dry system. But i'm taking the proper precaution to make sure i dont @!#$ @!#$ up. The reason i need to do this is ecause i have a fuel pressure saftey switch.
Tuesday, November 29, 2005 7:29 PM
Oh I see. Yeah that set up should look really good and get the job done as well. Good luck with the install. Take some if you can. Don't believe their is much about that subject on here..
Thursday, December 15, 2005 12:45 PM
So did you ever finish the setup? How did it go?
PICS?......
