Solenoid Leak.. - Nitrous Oxide Forum
Solenoid Leak..
Wednesday, February 01, 2006 5:38 PM
My purge solenoid is leaking N20 into the outlet side, It isnt horrible but I can hear it Hissing out, So can I adjust it and if so how?
Or can I send it in for a rebuild?
Thats right, keep on killing innocent people and @!#$ everything up for others..YOU ARE TEH WIN
Re: Solenoid Leak..
Wednesday, February 01, 2006 6:07 PM
what brand is it? Thats not a good sign for a solenoid a rebuild should do the trick but... Is it new?
Check out my cardomain Team Altered
Re: Solenoid Leak..
Wednesday, February 01, 2006 9:25 PM
Have you tried removing all the connections, re-taping and re-tightening them? We've had this problem before as well--try the easiest fix before you go after the costliest.
Re: Solenoid Leak..
Thursday, February 02, 2006 2:29 AM
Its a dynotune purge kit, I dont think it is new..
And I dont think redoing the fitting is going to solve the problem because it leaks when there isnt even a fitting in the tap
Re: Solenoid Leak..
Thursday, February 02, 2006 3:34 PM
^ thats the assumption I had
