install question - Nitrous Oxide Forum
install question
Monday, January 15, 2007 12:27 AM
can i fit a direct port kit under my manifold(4 cylinder,carby) with the foggers pointing up,
have no room on top side of manifold.
will this way work? will it be just as good?
Re: install question
Wednesday, January 17, 2007 2:51 PM
mebbe if we knew what engine/car, we could help a lil better...
fill out your profile
Wednesday, January 17, 2007 7:03 PM
I don't know if it will fit, but mounting it on the bottom of the manifold will work the same, It doesn;t matter what position you mount the nozzles in(as long as they are mounted correctly) because the fuel and spray are under pressure. Gravity doesn't matter.
Monday, January 22, 2007 8:21 PM
the lemur wrote:I don't know if it will fit, but mounting it on the bottom of the manifold will work the same, It doesn;t matter what position you mount the nozzles in(as long as they are mounted correctly) because the fuel and spray are under pressure. Gravity doesn't matter.
What he said, what car do you plan on doing this to?
