anybody spraying with ADVANCED timing? - Nitrous Oxide Forum
Saturday, July 05, 2008 11:09 AM
timing is advanced 4 degrees over stock.
all i wanna run is a wet 35 shot, will it be ok?
Re: anybody spraying with ADVANCED timing?
Saturday, July 05, 2008 11:12 AM
I think its usually Timing Retarded
Saturday, July 05, 2008 12:39 PM
yeah i know but i had to give back the HPT i was barrowing and am now left with the timing where it is.
just wondering if calling for a death wish or if it will be ok.
Saturday, July 05, 2008 12:50 PM
I probably would return the timing to stock or retard it a couple degrees and put some colder plugs in.im not really familiar with nitrous though, know some but not alot
Saturday, July 05, 2008 1:23 PM
4 degrees advanced seems like a lot, 4 degrees pulled is the usual for a 100-125 shot. But then again I don't know man because a 35 shot really isn't all that much. Are you running it 4* advanced n/a?
Saturday, July 05, 2008 2:13 PM
^^^ yep, thats what its SET at anyways. its 28 degrees advanced total for n/a.
and for the record, ngk tr6 plugs are installed and i run nothing but premium gas.
Saturday, July 05, 2008 11:54 PM
as long as the A/F ratios stay in check you'll be fine with a 35shot.
_______________________
** Flat Broke Racing Inc.**
Sunday, July 13, 2008 7:50 AM
There is only one way to be sure, try it while logging it and look for knock.
- 93 mph in the 1/8 mile
Member of J-Body Of Michigan.
Sunday, July 13, 2008 9:01 PM
i would if i still had the HPT i was using plus i cant even afford to fill the bottle for the first time.
im planning on buying my own pro this winter though...
Friday, July 25, 2008 1:46 PM
see me tomorrow and I'd be glad to explain why timing is retarded with n2o. its not just about detonation.
sig not found
Saturday, July 26, 2008 7:49 PM
you would more than likely be ok running a 35-50 shot as long as you use race gas or at least 95 oct.
Saturday, July 26, 2008 7:58 PM
I suppose you'd also reccomment pulling timing under boost as well then huh?
Saturday, August 02, 2008 10:52 AM
generally the old school thing is to retard 1 degree for every 25 shot
Saturday, August 02, 2008 3:59 PM
well i know what im SUPPOSED to do, guys.
just wondering if anyone else had upped the timing and tried spray. just trying to find out if i should trailer it to the track or not
Saturday, August 02, 2008 9:03 PM
Well I can tell you that I do plan on advancing my timing with quite a bit of nitrous. I'm going to do with 110 race gas and go one degree at a time and see if and when I detect any knock. I just need to get my wideband first
Sunday, August 03, 2008 5:00 AM
Bingo. I have 27 degrees of advance on an eco w/ 23psi out of a 60 trim and 10:1 compression. The nifty thing that makes this all possible...110. I will also be adding a lil bit of juice to it by the end of the year and hopefully it'll be lots of fun. Post pics of the motor when I blow the thing sky high .
Wednesday, August 06, 2008 5:18 PM
huh.... im running 15degrees on 20lbs with pump gas..... hopefully in the next month or so ill do a retune on 114 or 116 and maybe hook up the laughing gas
R.I.P. Brian Klocke, you will never be forgotten
Wednesday, August 06, 2008 5:48 PM
Heck yeah!! When do you plan on spraying?
Monday, September 01, 2008 5:50 PM
Pump gas, water injection, 35-50 dry shot, 26-28* avd at WOT...160-175 KPA.....(if i remember right..the kpa part)
Chris
'02 Z-24 Supercharged
Friday, September 05, 2008 1:01 PM
^^^ nice.
i believe mine is set at 28* at WOT. i have a wet kit and no water injection so hopefully ill be all right. getting ready to see just how well it works pretty soon.
Friday, September 05, 2008 6:11 PM
the water injection was to cool the blower down....
Chris
Saturday, September 06, 2008 2:02 PM
definitely needed! the m45 gets so ungodly hot. although.. id love to feel the casing after a nice spray of nitrous through it
Saturday, September 06, 2008 10:24 PM
on a 95* day, with water injection (strait water, cooled faster) i would hit 75* intake air temps with in 4 seconds of hitting boost..
works great, and is a MUST for a Eaton.
N2O didn't seem to cool it down more.. but the case.. would get condensation on it.
Chris
