My build - Audio & Electronics Forum
My build
Sunday, February 27, 2011 1:04 AM
Ok so I guess I'll start out with all the sound deadening I did. I used mostly second skin products however I also used 60 sq feet of raammat and 20 sq feet of dynamat extreme. They are just not pictured
80 sq ft of second skin damplifier pro
80 sq ft of Luxury liner pro(MLV)
3 gallons of spectrum
hood liner
First we will start with underneath the car. I sprayed a lot of spectrum underneath of the car
here is what it looks like stock, as if you guys didnt know
and after several layers of spectrum
It pays to have a dad with an oil pit in his shop
Re: My build
Sunday, February 27, 2011 1:10 AM
ok now time for the inside
first a nice gutted picture for ya(and every single piece of wire that belongs to the audio has been replaced to excuse the mess)
and it begins. I didnt take many pictures of the mat for some reason but rest assured I got extremely good coverage
now time for the mlv. I really want to go back and do another layer. A 5% void in this stuff can still allow a substantial amount of noise to come through and if you look closely I left plenty of voids
Re: My build
Sunday, February 27, 2011 1:14 AM
and now the doors. I did not take many pictures of them, however, I did go overboard on them. Each door has about 40 sq feet of deadener, a layer of ccf, and a layer of mlv. they are VERY SOLID
and yes I even did the hood lol
and finally the trunk. Again I didnt take many pictures final product aside. I did not go crazy with the mat back there however did spray a decent amount of the spectrum
Re: My build
Sunday, February 27, 2011 1:21 AM
now time for the good stuff. THE AUDIO!!!!!!!!!
here is a picture of some of the equipment. I'll post all the pics I have from when I built it however, I have sold the amps I have in the build. I'll post pics of new amps later
we will start with what I did under the hood
here is how it started
then I did this
took this out
replaced with this. I get a million hp from this thing!!!!
a few runs of 1/0
and the finished for the most part
now lets go inside the car. this is a picture of my headunit. It looks kind of goofy however, I have redone this since the picture and it looks great now. I now have the proper dash kit for it
and now the trunk. I didnt take many pictures but thats because I never finished it
now as far as install pics go thats all I have for you however here is a picture of the equipment that is going in when I have the time. All Image Dynamics.
Re: My build
Sunday, February 27, 2011 1:32 AM
oh yeah and my a pillars. ( i still need to wrap them in suede)
and the car itself. just an 04 cavalier
and here is my over cavi
Re: My build
Sunday, February 27, 2011 9:36 AM
looks like your having allot of fun, battery setup looks nice, id just look at recutting the top plexi piece. doesnt look straight and would look 10x if you really finished the top cover piece off nicely. i like the equipment your switching out to. ive been using id stuff for years. get some pics of the finished pics of the headunit and such so we can see how that turned out.
Re: My build
Sunday, February 27, 2011 10:16 AM
Thanks man. Yeah I forgot to mention that my plexi over the front 2 batts was only a mock up to see how I liked it. I just used cheap 1/8" plexi for that. I bought some 1/4 to redo it with just haven't had the time.
And with ID products I absolutely love them. They make solid products and customer service is excellent. The owner actually cares about the customer. He and I have bs'd a lot about my install and he helped pick everything out
Re: My build
Sunday, February 27, 2011 1:29 PM
Cool stuff. Couple questions though:
Why did you mount the tweeters so high? Seems like sort of the worst place to mount them since the L/R distance difference is bigger than even a sail panel mount.
Where are you going to mount those waveguides?
Did you run your wires under the barrier material?
How did the carpet fit over it all?
Re: My build
Sunday, February 27, 2011 2:33 PM
Believe it or not the tweeters sound incredible well up there regardless of the different paths length. That is where my time alignment comes into play. I have just about a perfect center image. It occasionally favors the left side. Just depends on the song. My a pillars where actually built by one of my buddies on team id. They are exact replicas of what he has in his cavi when he competes.
As far as the horns go they are made to be mounted underneath the dash. Once these are installed I will no longer be using my tweeters unless its just 10k Hz up and only if I feel my soundstage is low.
All of my wiring is mounted above the mlv and the carpet fits pretty well surprisingly
Re: My build
Monday, February 28, 2011 4:51 AM
bradsk88 wrote:Cool stuff. Couple questions though:
yeah the horns should take care of his highs for the most part. allot of time with the smaller cars and using horns you get a great width and deapth (extremely great) but height can suffer a bit so guys will run tweeters up high crossed over pretty high just to pull the sound stage up slightly.
i used to talk with matt allot before i would build my boxes just to get the most out of them. been years since i talked with him. not even sure if he's still with them or not. i have been looking at there 5 channel amp to possibly power my system in the trailblazer with an idq15 for bass (if there still making the 15)
Re: My build
Monday, February 28, 2011 6:34 AM
Matt is still with them. He personally modded all 4 of my amps. Great guy. And they are no longer making an idq 15 however the v2 is still available
Re: My build
Monday, February 28, 2011 9:51 AM
Well dammit. Ive been looking into an iDQ 15 for my sub too. I suspect the iD12 wont last the summer. I may beat on it a little bit.
I wish I had the time/patience to rip out my interior and do my install how it needs to be done.
Re: My build
Monday, February 28, 2011 8:38 PM
Brian Smith wrote:As far as the horns go they are made to be mounted underneath the dash. Once these are installed I will no longer be using my tweeters unless its just 10k Hz up and only if I feel my soundstage is low.
I understand that, but there's not much room in our footwells as it. Will you be mounting them behind the plastic of the underdash, or below the dash, sacrificing foot space?
Brian Smith wrote:All of my wiring is mounted above the mlv and the carpet fits pretty well surprisingly
Above eh? I like running my wires under the mlv so that there is a uniform surface for the carpet to lay on.
Re: My build
Monday, February 28, 2011 10:17 PM
Can't tell in my car where the wires are so no big deal to me.
And the horns just go in the bottom portion of the dash as far back as possible. Shouldn't mess with leg room much
Re: My build
Tuesday, March 01, 2011 4:36 AM
Brian Smith wrote:Matt is still with them. He personally modded all 4 of my amps. Great guy. And they are no longer making an idq 15 however the v2 is still available
good to see matt still is with them. dissapointing on the lack of 15's though. may have to start searching ebay for a used one.
Re: My build
TheSundownFire (GME Chat) wrote:Well dammit. Ive been looking into an iDQ 15 for my sub too. I suspect the iD12 wont last the summer. I may beat on it a little bit.
tell you what the id's are nice but there is a definate diffrence in sound with the idq.
Re: My build
Tuesday, March 01, 2011 5:49 AM
wow. awesome job so far. Those horns are going to be bad ass. I only got 500k out of my intake. Thats bs you get the whole million
Re: My build
Tuesday, March 01, 2011 10:35 AM
Dont tempt me Jason. Ive got tax return money sitting here begging to be spent on more audio.
Re: My build
Wednesday, March 02, 2011 4:23 AM
i want to get started on it bad but we have overspent during the christmas season well all of winter in general lol. and i have to finish the sunfire. sucks when u have to hold off on stuff lol.
Re: My build
Wednesday, March 02, 2011 8:29 AM
Jason, u know who to call when the wife gives you the green light on the trucks audio lol
And to the op: if you bhave any good amount of damp pro leftover let me know
"You really need to staple your face shut"-THE Joey Baggs.
