HIDs only have High beam - Audio & Electronics Forum
Sunday, September 11, 2011 3:07 PM
I just put HIDs in my car and they work. However there causing the the headlights to stay on High no matter what. They are a High/Low kit.
Has anyone else had this problem?
Re: HIDs only have High beam
Sunday, September 11, 2011 3:29 PM
2 things can cause this
1. malfunctioning bulb motor
2. relay wired in reverse for hi/low beams singal (or not even wired at all or incorrectly for lows)
Sunday, September 11, 2011 4:49 PM
Now that its dark I do in fact I have drivers side high/ low, but not passenger side, and it still only shows high beam on the dash. Would a relayed wired in reverse still cause this? Im pretty sure there both wired up the same, but Ill have to double check in daylight
Wednesday, September 14, 2011 4:28 PM
Definitely not the wiring.....Could it be the relay?
Wednesday, September 14, 2011 4:39 PM
like i told you before. most likely it is a relay. there's 2 sets of wires going into ballast, there's a good chance that 1 of them is cross connected between highs and lows
after all it was made in china and those poor bastards don't have a very good understanding on how to wire up relays
Friday, September 16, 2011 4:08 PM
Switched headlights to the other side and both have hi/low, but not when there on their side...... So it cant be the wiring.
