splicing 194 bulbs to 00-02 cav headlight harness? - Audio & Electronics Forum
Sunday, December 11, 2011 3:50 PM
I can't figure out the wiring for this.. what should be a straight forward splice.
I've got a Sunfire front end swap on my Cavalier, using 00-02 cavalier harness for the headlights.
Which works fine right now on the 95-99 bumper I got, fixing to swap to a 00-02 base bumper.
And the 3157(I think thats the bulb size) lights up the front round markers, and I need to add 194 bulbs to light up the side markers on the bumper.
I've tried several times and I can't figure out which wire is power, constant/steady and the turn signal.. signal.
Re: splicing 194 bulbs to 00-02 cav headlight harness?
Monday, December 12, 2011 6:54 AM
Don't the lights on 00+ use a constant power wire, and then 2 ground wires to switch the lights on and off?
Monday, December 12, 2011 6:49 PM
why are you using a 00 harness on a 96 car????/ different harness
if you attepmt a wiring project you should have the schematics for that so you know what your doin cause its prettyeasy to see when its laid out on paper
PS- 00 sunfire harness has all this done for you but still don't know why you need an 00 for a 96 car
194 bulbs
LF
pin a light blue
pin b brown
RF
pin a dk blue
pin b brown
JBO since July 30, 2001
