Very wird radio issue!! - Audio & Electronics Forum
Monday, January 09, 2012 5:27 PM
do you know what it mees when the scosche wiring harness chime song several times and stop the radio when you start the car?? sorry im french i did my best lol
car : cavalier 2001 2.2l
the scosche wiring harness is breen new
pioneer radio
Re: Very wird radio issue!!
Tuesday, January 31, 2012 4:07 PM
So does anyone have an answer for this I have the same issue, turn the ignition forward to run everything works perfect. start the car and there's no power.
Tuesday, January 31, 2012 4:30 PM
I was having the same issue, are u guys using the relays too??
Tuesday, January 31, 2012 5:11 PM
I'm using the scoche GM2000 plug from the factory plug to the radio plug with the box with the chime in it.
Wednesday, February 08, 2012 6:59 PM
check grounds maybe? I know i had a problem with another gm car that for some reason would lose ground to the radio when i turned the headlights on?? never figured out why actually, ran a new ground to the metal in the radio housing and power went away... i'd say pull your radio out and check your power/grounds when you turn the car on.
Tuesday, February 14, 2012 12:56 PM
ya I am using the same kit, I wonder if they ever had problems with it?
Wednesday, February 15, 2012 4:32 PM
I wouldn't know... what are you using relays for exactly?
