wiring diagram needed 2000 sunfire - Audio & Electronics Forum
Tuesday, March 26, 2013 8:05 PM
in looking for winging diagrams for everythng underneith the steering wheel, as in everything around the ignition thingy, but any and all interior wiring diagrams are appreciated.Im trying to clean up the hackjob alarm install my perviouse owner did and i have a hard time finding and wiring diagrams whatsoever :/ thanks for your input!
Re: wiring diagram needed 2000 sunfire
Wednesday, March 27, 2013 2:22 PM
This is all I have available right now.
2000 Pontiac Sunfire Alarm, Remote Starter, Keyless Entry Wiring Information
Constant 12V+ Red Ignition Switch Harness
Starter Yellow Ignition Switch Harness
Ignition Pink Ignition Switch Harness
Ignition 2 White Ignition Switch Harness PCM and Cluster
Accessory Orange Ignition Switch Harness (Heat/AC)
Tach White Harness near Battery
Neutral Safety Wire Yellow Ignition Switch Harness
Brake Switch White Brake Switch
Trunk Release Black/White (+) OEM Keyless Module Driver's Side of Trunk
Trunk Pin Black (+) Light in Trunk
Parking Lights Brown (+) Light Switch
Head Lamp Dark Blue (-) Pink (-) at Head Light Switch
Door Trigger Green/Black (-) And LT. Blue Block near Brake Diode Isolate
Door Lock Light Blue Either Kick Panel (Passenger's Switch is Master)
Door Unlock White Reverse Polarity
Driver's Lock Gray Driver's Kick Panel
Driver's Unlock Tan Driver's Kick Panel
Horn Wire Black (-) HEADLamp Switch
Windows Up LF=Dark Blue, RF=Light Blue, LR=Dark Green, RR=Light Green
Windows Down LF=Brown, RF=Tan, LR=Purple, RR=Purple
