wiring diagram for stock harness ? - Audio & Electronics Forum
Wednesday, September 19, 2007 9:23 AM
putting in a new head unit, have the manual for that but need to know what wire is what from the car. thanks i have a 2001
2001 2 door five speed 122k.
custom steering linkage pop
2000 s10 (THE WORKS)
Re: wiring diagram for stock harness ?
Wednesday, September 19, 2007 10:06 AM
Get yourself a wiring harness, it'll be your easiest bet instead of hard wiring.
Wednesday, September 19, 2007 10:25 AM
I have a wiring harness. I need to know what stock wires (that are in the car allready) go where. i've figured out all the speakers but i can't get the unit to power on. mostly im wondering what is (switched power) and what is the constant power
or do i have to run a wire to the battery for this
Wednesday, September 19, 2007 10:43 AM
Orange is 12v constant
Grey is illumination
Pink (I believe) is 12v keyed
Wednesday, September 19, 2007 12:01 PM
Power & ground:
Orange - Battery Positive Voltage (constant)
Red - Battery Positive Voltage (switched) Note: not found in 2000+ radio harness
Black - Ground
2000+ specific:
Purple - Class 2 signal, radio on (2000+ cars only)
Pink - Radio On Signal (2000+ Monsoon, amplified systems only)
Purple - Gain Control Signal to amp (2000+ Monsoon, amplified systems only)
Speaker outputs from radio:
Tan - Left Front Speaker Output (+)
Gray - Left Front Speaker Output (-)
Light Green - Right Front Speaker Output (+)
Dark green - Right Front Speaker Output (-)
Brown - Left Rear Speaker Output (+)
Yellow - Left Rear Speaker Output (-)
Dark Blue - Right Rear Speaker Output (+)
Light Blue - Right Rear Speaker Output (-)
from the FAQ and the sticky.
Friday, February 15, 2008 1:21 PM
Please excuse me bringing back a thread from September.
I looked around for more information here, but could'n find a complete answer.
I just grabbed a CD player from a 2000 Sunfire (non-GT; non-Monsoon).
From this and another post this is what I believe the wiring to be - please correct me if I'm wrong:
group #1
Purple (A1) = 12v Ignition
Orange (B1) = 12v constant
Grey (B4) = Radio Illumination/Dimmer
Black (B5) = Ground
groupe #2
Tan (A8) = Left Front Speaker (+)
Grey (A9) = Left Front Speaker (-)
Light Blue (A10) = Right Rear Speaker (-)
Dark Blue (A11) = Right Rear Speaker (+)
Black (A12) = Ground
Browne (B9) = Left Rear Speaker (+)
Yellow (B10) = Left Rear Speaker (-)
Dark Green (B11) = Right Front Speaker (-)
Light Green (B12) = Right Front Speaker (+)
Saturday, February 16, 2008 2:17 PM
Pretty much... just curious why you want to know... what car is it going into?
If you're trying to install it in a non 2000+ (aka Non-Class 2 car), it'll never turn on. You need the Body Control Module (BCM) only found in 2000+ cars, to tell the deck to turn on and off. It's a data wire, not a switched wire. No way around that....
Saturday, February 16, 2008 2:40 PM
Is there any way to get the BCM, put it in a pre-'00 car and fool the deck into thinking it's in the right kind of car?
This is news to me.
Yes I was going to try to put it in a pre-'00 car...
or at least confirm it worked properly and didn't need to be unlocked, then put it on eBay.
Saturday, February 16, 2008 2:54 PM
Not really. The BCM gets signals from the PCM.. so you'd need a 2000+ PCM as well to make it work right. I don't even think it would physically fit in the dash on a 95-99 car, since the 2000+ deck is a double DIN height, and the 95-99 is a 1.5 DIN.
Whatever car it does go into... will need to be "unlocked" by a GM Tech 2 diagnostic tool, as it's paired with the BCM from the factory. So you need to reflash the BCM into recognizing the deck once it's installed.
There isn't an easy way to do this... basically, it's got to be in a 2000+ car.
Saturday, February 16, 2008 6:13 PM
Thank you very much for your help!
Saturday, February 16, 2008 7:25 PM
ok, so rather than waste too much of my time in this matter I've listed this on ebay.
I can't find any "for sale" sub-forum, so I'll just post the link for the auction here:
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=280201603775&ssPageName=STRK:MESE:IT&ih=018
here is a posating in another forum regaurding this listing:
http://www.quad4forums.com/forums/showthread.php?t=13280
If any mods would care to contact me and show me where I should post my "for sal" ad, please do so...
(If you feel so inclined, feel frre to just make a listing on my behalf then remove this post.)
Wednesday, October 21, 2015 12:20 PM
So it's the purple wire that comes from the BCM that is the data wire, what is the BCM sending down that wire and can it be duplicated so the stereo can be put in an older car or in my case the garage?
I've done a lot of searching and haven't been able to find this info anywhere.
Monday, January 04, 2016 11:11 AM
This is the first time I've heard of someone wanting to keep a stock radio for any purpose other than a door stop... so I can't imagine there's much of a market for an aftermarket company to make such a device. I've never heard of one.
