Turbo downpipe size ?'s - Boost Forum
Friday, May 04, 2007 10:25 PM
OK all, Im going to be running a pretty standard turbo setup. 16G, intercooled, 10-12 PSI max. I'm needing to get my turbo downpipe fabricated. My question is, what is a good pipe size, and what does everyone recommend??? I have access to everything I need in 2.25" and was told that that would be just fine for my car. I've seen people on here run to 3" and they say that 3" is perfect. And there are others that say 2.5" is perfect.
I don't plan on running more than 10-12PSI max, and just after the downpipe, I will be upping to 2.5" high flow cat and possibly side exit exhaust. So what is everyones thoughts??? Will 2.25" be alright, or should I look for a bigger size to go with??? Thanks for everyones suggestions.
Re: Turbo downpipe size ?'s
Friday, May 04, 2007 10:38 PM
I have a 2.5 inch downpipe, 3 inch after that, no cat, with a apexi WS2 muffler, probably the best sounding 4cyl I have heard, in my opinion.
Saturday, May 05, 2007 1:31 PM
And also, I dont think a 2.25 downpipe is a very good idea, doesnt flow enough, you would notice a longer lag then somebody running a 2.5inch downpipe I am sure. Just go 2.5. I dont think 3 inch is nessisary, maybe if I had a GT turbo, or something with a 3 inch exhaust outlet, then I would have done a 3 inch downpipe.
Saturday, May 05, 2007 10:30 PM
I'm not really comcerned about sound. My car could sound like a dying emu for all I care, haha. All I care about is decent performance. So is it a definate no on the 2.25" downpipe, or do others have any other opinions? Thanks for your input Fst Cavy, I really appreciate it!!!
Saturday, May 05, 2007 11:19 PM
im running a 2.5 setup with a side exit...i have no problems with it and it sound really pissed off....
Sunday, May 06, 2007 6:34 PM
I had a 3" full exhaust from the turbo back, over the axle in my old Z24. Probably one of the reasons I was able to put down 221 WHP on just 8 psi with a really rough tune.
It's oh so cheesey!
Thursday, June 16, 2011 7:19 PM
im using 2.5 gets close to the fuel but going to wrap
Thursday, June 16, 2011 7:42 PM
If you care about performance stay away from 2.25, honestly unless you have a ln2 or 2200 2.25 is too small for a N/A build. I will personally be using a 3" but I would not use less than 2.5". Remember the less back pressure the happier the turbo, thats why you hear about people with factory turboed cars changing out the downpipe.
Thursday, June 16, 2011 8:01 PM
Zs Z wrote:If you care about performance stay away from 2.25, honestly unless you have a ln2 or 2200
And what..... A 3" down pipe to 3" straight back exhaust on a fully built LN2.. people always gotta be ragging on the LN2 motors..
Friday, June 17, 2011 1:57 PM
I worded that weirdly, I meant 2.25" was only acceptable on a N/A 2.2 LN2. When turboed the bigger the better ALWAYS no matter the engine.
Friday, June 17, 2011 2:01 PM
Lol I was just giving ya a hard time plus it gave me an opportunity to show off my latest update since no one ever commentson my build thread!
Friday, June 17, 2011 6:53 PM
It does look pretty badass!
Saturday, June 18, 2011 6:46 PM
Just go with whatever size the outlet of the turbine is, that's the correct size for the turbo as defined by the manufacturer.
Sponsored by: Kronos Performance
Monday, June 20, 2011 8:35 AM
My 16g will have a 2.5" downpipe and flare to 3" at the cat
Jason
99 Z24
LG0/LD9 for Life
10 Year Bash Veteren
Monday, June 20, 2011 8:51 AM
im running 2.5" all the way back on 10psi. 3" is over kill unless your hp goals are high.
Monday, June 20, 2011 9:07 AM
Leafy wrote:Just go with whatever size the outlet of the turbine is, that's the correct size for the turbo as defined by the manufacturer.
The only even PARTIALLY correct answer in this thread...
The outlet of the turbine dictates what size pipe you will want to run... generally a quarter inch bell outlet up to the exhaust pipe diameter is all you need. Do you realize how much more area you present for the exhaust gasses just upping one quarter inch?
my setup has an outlet of 2.25"... I used a flange that has a 2.25 hole, welded the pipe to the flange, and then blended the 2.25 to the 2.5" pipe.
You do realize that a 3 inch pipe will flow up to 600hp worth of air correct?
allowing exhaust to flow out of the turbo will help spool... but come on people.. a 2.25 inch T3 turbo exit or even smaller 16g outlet going up to 3 inch? Thats rediculous.
Some of you need to read This...
Monday, June 20, 2011 11:19 AM
My car is at a professional speed shop and the goal is 500whp. 3" is dead on where I need to be.
Monday, June 20, 2011 2:00 PM
I own max boost and have read it numerous times. Hell he's the one I got the whole, "if your turbine outlet is x size, no need for your downpipe to be bigger than x."
Monday, June 20, 2011 2:55 PM
3" here, aiming for 400-450 to the wheels
Monday, June 20, 2011 5:52 PM
For practical purposes, that's fine, but technically from a performance standpoint, that's incorrect. Sure there is a point of diminishing returns, but generally, a larger/higher flowing exhaust not only increases turbo response, but it also helps improve turbine efficiency and reduce EGT's. Technically, the ideal exhaust would be a flared or tapered "megaphone", which helps create an impedance match between the diameter of the turbine wheel and the atmosphere (think Helmholtz)...but this isn't really practical for anything short of a rail. Also, if you're running a CAT or muffler, those are restrictions to contend with, which reduce your effective diameter and therefore a larger exhaust makes even more sense..
I have no signiture
Monday, June 20, 2011 5:53 PM
Right, I was referring to down pipes in a street driven application. And only down pipes.
