Need Help! fuel, how much psi, and other boost questions - Boost Forum
Friday, December 07, 2012 7:10 PM
So i decided to go turbo and got questions any help will be great
1. what fuel pump that you guys havent had trouble with? blazer, racetronix, walbro?
2.im planning to go 8-10psi maybe 12psi have 2 sizes i can get
57 trim .63 a/r or a 50 trim .48 a/r
Supporting mods will be wiseco pistons eagle rods 8.9:1 CR P&P head from Ortiz Performance
i have a spare eco block im sending to get remanufactured so basically ill have a brand new engine
How much psi will it hold?
Re: Need Help! fuel, how much psi, and other boost questions
Friday, December 07, 2012 7:24 PM
I'd get the racetronix w body fuel pump w/the harness and the 57 63 turbo. With a good tune you could run 20 psi, or prob a little more. You could also get a Hallman manual boost controller or go big with an electronic boost controller since it sounds like you have a 8-12 psi spring...that's if you ended up wanting to run more boost.
2004 Cavalier Sedan
Friday, December 07, 2012 11:04 PM
Well the kit comes with an 8psi spring and it comes with a manual boost controller how much psi can i get out of that? & will my eco hold up 18psi and be street friendly? its an automatic 4t40e
Will it boost quick with that turbo?
Would you happen to have a part # on the pump?
Saturday, December 08, 2012 10:21 AM
What about the walbro 255lph inline fuel pump? can i install that and leave my stock pump?
Saturday, December 08, 2012 12:07 PM
Id do the racetronix pump things amazing and your stock probably needs replaced any ways.
Google racetronix, then click fuel componets and click fuel pump assemblies (racetronix ) then ls1 (very last one)# fpa-001. Quick simple search
Get the harness with it worth the $50
Saturday, December 08, 2012 12:24 PM
I gave you the f body pump same thing just has a sleeve you can take off, w body pump is on there too
Saturday, December 08, 2012 6:23 PM
FPWH-001 is the part num for the harness that others are using, to include myself.
2004 Cavalier Sedan
Sunday, December 09, 2012 7:37 AM
You cannot just simply put in an inline pump. the stock pump wont be able to keep up the flow to supply the inline.
I am running the .57 trim, t3/t4, stage 3 wheel, .63 a/r and I love it. I wouldnt change mine to a bigger one for a LONG time.
The amount it will take can only depend 100% on your tune. If you dont have a good tune, then it wont even be able to take 2psi before it blows.
