05 cav 9psi 2.8 pulley? - Boost Forum
Sunday, June 29, 2014 3:06 PM
on stock pulley was running 7psi now i put on 2.8 zzperformance zz tensioner over sized tensioner pulley and im only pulling 9psi on a good day checked bypass seem to have no problems anyone know wuts going on???????
Ya buddy
Re: 05 cav 9psi 2.8 pulley?
Sunday, June 29, 2014 3:58 PM
Yea that's not right. Does it stop gaining boost at a low rpm like 4k. Or does it climb all the way to redline.
If it's stoping at a low rpm I would say the valve or the blower itself if it's climbing the whole way to redline it could be a bad gauge
2002 cavy 2.2 ecotec m62 Getrag trans
Tuesday, July 01, 2014 8:18 AM
check gauge about 4k it stops at 9psi took all vacuums off valve still same thing
Ya buddy
Tuesday, July 01, 2014 8:38 AM
maybe your engine flows better
pressure isn't everything
2001 Olds Alero (LD9)
636 whp / 543 ft-lb
@turboalero
Tuesday, July 01, 2014 10:04 PM
Do you have the heatexchanger hooked up? And what's your vac at idle?
Wednesday, July 02, 2014 5:53 AM
What exhaust are you running, stock l61? intercooled?
"In Oldskool we trust"
Wednesday, July 02, 2014 11:34 AM
running header and 2.5 pipe, intercooled, stock l61 vac @ idle 17 ish car is driving me crazy really think belt is slipping on harmonic balancer want to get rite before my last tune till i build billet motor
Ya buddy
Wednesday, July 02, 2014 11:35 AM
feels like turbo car with 10 psi waste gate but no lag lol
Ya buddy
Wednesday, July 02, 2014 11:45 AM
Didn't realize you're running the stock sized belt. Even with the oversized tensioner I bet the belt is slipping. I'm running a stage 2 belt on a 2.9 without the oversized tensioner and it's the perfect size. So I'd guess your belt is just a little too big. You may or may not have to swap back to the stock sized tensioner with a stage 2 belt but you'll have to wait and see.
When you watch the boost gauge does it go to 9psi right away and stay there or does it start to bleed off?
Wednesday, July 02, 2014 11:59 AM
gos to 9psi and stays
Ya buddy
Wednesday, July 02, 2014 12:00 PM
belt is super tight tho
Ya buddy
Wednesday, July 02, 2014 2:31 PM
The belt may be tight, but remember the faster you try to spin your blower the more resistant it is to spinning so enough tension at 5psi does not equal enough tension at 9+psi. I had some slippage issues and I bought the adjustable tensioner that ZZP sells, problem is gone.
Thursday, July 03, 2014 7:44 AM
i have zzp tensioner already
Ya buddy
Thursday, July 03, 2014 12:50 PM
Any rattles or noise other than the characteristic whine from the supercharger? I still think your belt may be slipping but just trying to cover everything.
Thursday, July 03, 2014 2:57 PM
You said your Vac is at 17, is that in inHg? I idle ~21inHg/10psi. Might want to check for a Vac/boost leak at your IM gaskets.
Friday, July 04, 2014 11:43 AM
no vacume leak checked with carb cleaner and no noises last nite i put cross cuts in blower pulley and harmonic pulley still the same boost so i really dont know wuts the deal
Ya buddy
