2.5 bar map - Boost Forum
2.5 bar map
Sunday, October 05, 2014 7:44 PM
When supercharging the 2.2 ecotec with gm flash I am to use a 2.5 map. When doing so do i fully remove the original one from the system along with the IAT senor or do i leave the original one in and just splice into them?
also on a side note how are the throttle cables secured?
Any info would be great!!!
Re: 2.5 bar map
Monday, October 06, 2014 12:16 PM
Here, you remove both and wire it in like so.
Re: 2.5 bar map
Monday, October 06, 2014 2:23 PM
Great thanks Alex. Any idea on the throttle cable?
Re: 2.5 bar map
Monday, October 06, 2014 3:41 PM
Stocker works fine. I'll refer you to this..
http://www.j-body.org/forums/read.php?f=40&i=183438&t=183438
"In Oldskool we trust"
Re: 2.5 bar map
Monday, October 06, 2014 4:35 PM
Y3llowCav wrote:Stocker works fine. I'll refer you to this..
Thanks for the link, that thread has helped me out emensly in gathering and installing parts.
I have to ask though would be possible to post a picture of your throttle cable clamp.The cable is the same but how is it secured. On the stock set-up there is bracket that would hold your throttle and cruise control cables.
I have no cruise control.
Re: 2.5 bar map
Monday, October 06, 2014 5:09 PM
You just reuse the stock bracket. It only bolts to the throttle body. The tb is just rotated.
Re: 2.5 bar map
Monday, October 06, 2014 5:42 PM
GAH thanks, I hadn't removed the black piece myself, was not sure how it attached.
Thank you
