1psi = how much horsepower? - Boost Forum
Monday, February 14, 2005 5:45 PM
i was just wondering about how much horsepower u gain per psi?
<img src=http://registry.gmenthusiast.com/images/notsofast/chevy2.JPG>
Re: 1psi = how much horsepower?
Monday, February 14, 2005 5:53 PM
Monday, February 14, 2005 6:01 PM
1psi = 7-10hp
Low fire stop being such a Fag and answer new peoples Q's
95 Talon Tsi AWD 450whp.....can't do that jbodies
Monday, February 14, 2005 6:06 PM
Because we all know that gays don't answer questions...
tool
- Interior FAQ -
J-Body of Michigan -
Monday, February 14, 2005 6:38 PM
There is no psi = hp correlation.
Monday, February 14, 2005 7:11 PM
are u @!#$ kidding me there is psi = hp correlation its called 7-10hp per psi. Why don't u learn a little about boost before you open your mouth. Go on any forum that knows cars www.dsmtuners.com and say that same @!#$ and you will be band. Idiot
Monday, February 14, 2005 7:19 PM
speaking of tools /\ /\ /\
Monday, February 14, 2005 7:20 PM
lol.....cfm makes as much of a difference as psi.
A turbo that is too small for an engine will make alot less power than a turbo that is sized correctley at the same psi.
Being a turbo god....you should know that.
Monday, February 14, 2005 7:22 PM
and I would love to see you call Ron an idot to his face.
What is it with you DSM asshats. One extreme to the other.....cool as hell....or stupid as hell. You guys are either one or the other. Guess which one you are.
Monday, February 14, 2005 7:26 PM
Spoolin wrote:are u @!#$ kidding me there is psi = hp correlation its called 7-10hp per psi. Why don't u learn a little about boost before you open your mouth. Go on any forum that knows cars www.dsmtuners.com and say that same @!#$ and you will be band. Idiot
You've got to be kidding me. You are the classic description of newb.
#1 - You flame a long standing, well-informed and highly regarded member.
#2 - You spout information you don't remotely understand.
#3 - You demonstrate a tremendous lack in the ability to spell and use punctuation, capitals, or sentence structure
#4 - You call somebody an idiot when clearly, you're the idiot.
#5 - You e-thug out on a messageboard. Way to be tough.
7-10 HP / PSI - would you like to show me where, exactly, this magic number comes from? Please, oh Lord of boost who knows all and decides do diss and dismiss members of this forum - EXPLAIN to us where you get that magical number from.
Ever hear of efficiency? Ever hear of combustion temps? Running rich? Pulling timing? Advancing timing? Compressor maps? Lag? Boost threshold? Exhaust velocity? Compression?
Every one of those is a factor in the hp/psi equation... and every car is different. Some make 5 hp / psi... some make 20 - it's all about how you set the car up.
But - I know all you're going to do is flame me and call me an idiot because you know all. So please... magnificent one... explain it to us.
Oh.. that's right. You can't - because you're completely misinformed by a bunch of DSM tuners.
Also - if your unfounded theory proves true, you're running 23 psi on your 1995 Talon with 450hp... so that's roughly 161 - 230 whp you're making on the psi you're putting out.
450 - 161 = 289 base N/A WHP
450 - 230 = 220 base N/A WHP
You think you're making that kind of WHP N/A HAH! Dream on. You just disproved your own theory buddy. In fact - there is no way according to your theory you're near 450 hp... it's more like 300 - 340 according to your calculations.
Way to show off the newbness... asshat. You might claim to have a fast DSM - but you sure aren't showing it off are you? In fact - if you don't have a J-body, you shouldn't be on this site at all. This will be reported to Dave.
Enjoy fixing your turbo sh!tbox every few thousand kilometers.
-Chris-
-Sweetness-
-Turbocharged-
Monday, February 14, 2005 7:30 PM
good god you all bitch alot.
7-10psi depending on turbo size/fuel to air mixture.
wheel size can be a factory too when boosting.
450whp DSM
Sould be approx 550engine hp
205 stock eng hp @ ?10?psi and 345 more hp from boost
@10/psi would be running 44.5psi of boost
@7/psi would be 59.2psi of boost
My car's faster w/o boost and AWD.
sig not found
Monday, February 14, 2005 8:02 PM
yes i am stupid as hell to make the hp that i do. generally speaking 7-10hp per psi is the norm. Sry if u think i'm a dsm ass. Take a look at it this way Imagine you have a box that holds 550 CF. You can pack 550 cubic feet of air in it and it's nothing special. Or you can pack 1650 cubic feet in it and now you have boost (3psi if I am thinking straight). Sure you can do it, but your box will weigh more (mass) with 3x the air inside it. I think this can illustrate the difference in CFM and lb/min ratings. CFM is the physical size of your box. Lb/min is how much air you are cramming in it at a specifc rate.
Monday, February 14, 2005 8:03 PM
Think of it this way, the engine at a given rpm draw a certain amount of air (this volume is fix and the formula is given on the page since we know the rpm and the capacity of the engine) so if the pressure in the system is constant at 15psi, how can one turbo flow more than the other? It doesnt. What's different is a t25 spin more rpm to push the air to maintain 15psi compared to a 16g. This makes the 16g compressor wheel more efficiency than the t25 because it pushing cooler air out. With these information (engine capacity, rpm, boost, temperature), you should be able to plot out a graph on the comp map of the turbo you wish to run and see how well it work.
Let's take for instance the T25 and a 16G both have the same TD05H wheel (which is not true but just for comparison purposes), then the only advantage the 16G has over the T25 is the better efficiency comp wheel. However, this is not the case, the 16G has a larger TW which allow more flow. So, remember the hot side plays an important role when picking a turbo because what you want is the most flow through the whole system.
Monday, February 14, 2005 8:05 PM
If you run through the math, you find that while an increase in compression efficiency does lower the compressor outlet temperature, its not that big of a gain.
The outlet temperature is only dependant on two things: the efficiency and the pressure ratio (or the outlet pressure/inlet pressure). And if we keep the boost level constant, we only have the efficiency to deal with.
At 15 psi boost the pressure ratio will be about 2.25. With a 60% compression efficiency and a 80F inlet temperature, the outlet temperature should be about 315F. Suppose you put some new turbo on and it has a compression efficiency of 70%. The new outlet temperature is about 280F. 35F drop is pretty good, but is it really worth? Turns out the colder outlet temp increases the air density by 4.5% If you had a nonintercooled car, that should mean (all else being equal) a 4.5% increase in mass air flow, and a 4.5% increase in power. Think about that, 10% better efficiency leads to a 35F drop in temperature, but that by itself is only worth 4.5% more air flow on a nonIC car.
But toss the IC into the equation. An air/air IC can at best get the air down to ambient temperature. If you study heat exchanger theory, you find that dropping the inlet temperature by 35F doesn't mean the outlet temperature also drops by 35F. The IC kind of dampens things, on the one hand it doesn't have as much heat to transfer with the colder inlet, but on the other hand the closer you get to ambient air temperature the harder it is to get there. Net effect, if you drop the inlet temperature by 35F then the outlet may only drop by 20F. And what is that worth? A 20F drop in the IC outlet only increases the charge air density (and therefore mass air flow and therefore power) by a little over 3%.
To sum all that up, on an intercooled car, an increase in compressor wheel efficiency from 60% to 70% (a pretty big jump) will only net a 3-4% gain in air flow *from temperature effects alone*.
When you changed the charge air temperature from 165 F to 120 F you cheated. That is why you got the big air flow increase. In reality it will be a lot less.
But still, people put on bigger turbos and do see more power at the same boost level. If its not air temperature, then what is it? I think it's two things (and this is my opinion, remember my qualifications, so take it for what its worth), and they are both on the exhaust side.
As you so correctly mentioned, when you swap turbos you swap turbine sides as well as compressor sides. A better flowing turbine side will reduce exhaust backpressure. Less backpressure means less exhaust left in the cylinder after the exhaust valve closes, which means more room for fresh air on the intake stroke. This means increased volumetric efficiency, or more air flow at the same charge air temperature and boost level. It's like adding more cubic inches! I believe that if you kept the compressor side exactly the same and changed the turbine side to something more freely flowing, you will see a power increase. And you do. Bigger turbine housings give a power increase, even though you haven't changed the compressor side at all. Might add some lag and such, but ultimately power is improved. It's similar in concept to getting rid of a cat converter or a restrictive muffler. Lower backpressure = improved VE = more air flow = more power. So thats one thing.
The other thing I think does come from improved compressor efficiency, but it isn't a temperature thing. It takes power to turn that compressor wheel, hp that is extracted from the exhaust by the turbine. If you improve the compression efficiency from 60% to 70% you need something like 20% less hp to drive the compressor wheel. Power to drive that wheel comes from exhaust temperature, exhaust flow, and exhaust pressure. If you reduce the power required by the compressor, then the exhaust flow that the turbine wheel needs goes down (ie more exhaust through the wastegate) and the exhaust pressure required goes down. And again, the lower backpressure means improved VE, more air flow, and more power.
Sorry this has been such a long book, but to sum up: IMO, a bigger turbo at the same boost level makes more power, but not due to temperature effects, but mostly due to improved VE. If you change compressor sides and don't change the turbine side, I don't think you'll see nearly the gains that someone who gets a whole new unit sees.
Monday, February 14, 2005 8:09 PM
well you just proved me right...nobody can type that much in 2 minutes...nice cut and paste
Monday, February 14, 2005 8:12 PM
Thanks for cut and pasting that - part of it was from our own faq.... way to go.
You still didn't answer the question. WHERE does your magical 7-10 hp/psi number come from?
And how does it apply to your car? Remember, your own theory proved your car isn't making 450 whp.
-Chris-
-Sweetness-
-Turbocharged-
Monday, February 14, 2005 8:18 PM
lmao, you sir are retarded.
so is that why when i dynoed 3 psi i was gaining a net of 18hp at the wheels per lb of boost??? didnt think so. seems a bit off of your magical 7-10 figure.
tool
12.6 @ 114.6 MPH
Monday, February 14, 2005 8:20 PM
I found the post he copied!
Hi guys, at Doug's invitation I thought I would drop in and contribute if I may. I wrote the article on the turbo Buick site, and I'm glad I did since I've "met" (electronically anyway) lots of interesting people from all over the world who share our interests.
Just to let you know where I'm coming from, I'm not a automotive turbo expert. I am a chemical engineer that does design work in the refining and petrochemical industry. As such I have to deal with things like centrifugal compressors and turbines (among many other things). Biggest one I've done so far is a 4 stage compressor boosting from 5 psi to 600 psi that took a 30,000 hp turbine to drive it! I'm telling you this so you can judge whether or not to believe anything I say. Too many internet experts out there that might know what they are talking about, and then again they might not. I think I know these things, but my knowledge isn't specifically automotive in nature. The same principles apply though.
Anyway, on to work. DCJ98GST, I don't think I like the conclusion you arrived at with your example. I hope you don't mind me poking at it for a second. You came to the conclusion that a bigger turbo might flow 15% more at the same boost pressure. I think you made a bad assumption that led you to that answer, and that was the charge air temperature.
I could on, but I think I've done enough damage here for today
John
Here is the link:
http://www.dsmtuners.com/forums/showthread.php?t=131839&highlight=air+ambient+temperature
Monday, February 14, 2005 8:21 PM
Monday, February 14, 2005 8:51 PM
OWNED....bad if I say so myself.
-Phillip -2000 Z24 Supercharged
176.2whp 172.3 ft lbs
Monday, February 14, 2005 9:07 PM
boost increase is to much a varabile to say everyone gains between this much and that much. (i.e. 7-10)
but i think that numbers based on a average gain of all cars. not just jbody
Monday, February 14, 2005 11:55 PM
proves that you cant hate the car.. its the driver.. iv only met 1 dsm owner that was a cunt... most of them were pretty cool..unlike the majority of the honda boys that are ass hats.. (not all of you). just the majority.
Tuesday, February 15, 2005 12:40 AM
i'll prolly get banned for this but no one comes on the org and flames on shifted but i got something for you spoolin
'\' \ _.·´
\ \ spool on that
Tuesday, February 15, 2005 12:41 AM
@!#$ didnt come out
