Which motor needs MORE GAS? - Boost Forum
Wednesday, February 23, 2005 4:29 PM
Ok guys, well as you know I am doing my Turbo set up, the only question I had is?
On the fuel feed/return, on of the lines is thicker and one is thiner.
Which one is feed bigger or the smaller one, it makes sense the bigger one but I might be wrong, so on the part of the fuel lines where you need the Quick disconnect tool where the rubber fuel line becomes a hard line and runs to the back you can see that one of the lines is bigger and one smaller, which one is which one??
Also, I had a 2.4L 10.5:1 and .040 over.
Now I have a stock Eco.
Which motor needs more gas per pound? I am thinking the 2.4L, but amount of the air the Turbo pushes will be the same through the both motors no??
On the 2.4L I was able to run 5-6 PSI on the stock injectors and 12:1 FMU disk, I am wondering will I be able to run 7-8 PSI on the Eco with the stock injectors and 12:1 disk.
I don't have the 5 PSI spring anymore.
"""i was told that I am able to do it, but this source is questionable"""
What cc are Eco stock injectors 2002 if it matters??
I have some pic of my Turbo set up I will post them later, thanks.
Best time:"""11.946""" @ 114.73 mph @17psi 1.83--60"
11 second daily driver!!!!
Race Related 727-561-9440
Shop of choice for your 11 second J body!
Also, built bottom end and or top end LSJ and L61's available.
13's ----12's ----11's ----10's
Re: Which motor needs MORE GAS?
Wednesday, February 23, 2005 4:43 PM
here is some.
I hope you guys like it, I will get some more.
Wednesday, February 23, 2005 4:55 PM
Its pretty easy to figure out what the return line. The return line is the one that comes out the bottom of the FPR.
Not sure what size the eco injectors are.
Wednesday, February 23, 2005 5:10 PM
Ok I guess it is the same where they disconnect on the 98 Cavi.
Shifted, what do you think about the 7-8 psi on stock injectors, a no no?? I think.
Wednesday, February 23, 2005 7:17 PM
Depending on the size of the turbo, I would venture to say no. It would be "ok" for a smaller T3 or something similar, but I think you have a pretty decent sized turbo and I would think that you would be really pushing it on stock injectors.
$300 in injectors... or ANOTHER motor swap, lol, I know you like motor swaps, but even the god of swaps has to have a limit
Wednesday, February 23, 2005 8:37 PM
Oh man, screw that not another one.
Yea, I want to dyno it just to make sure and stuff. rearangin everything sucked ass.
