What injector for 8 psi on 98 2200 - Boost Forum
Sunday, March 13, 2005 5:02 PM
I did a search and now Im really confused. What kind of injectors do I need to safely run 8 psi with a cartech fpr. I've heard 30lbs are good to get, but which ones?? Is there a set any cheaper than $400 that will fit the bill??
I have a 98 2000 engine.
<a href="http://www.j-body.org/members/purplhaze">My registry</a>
Re: What injector for 8 psi on 98 2200
Sunday, March 13, 2005 5:12 PM
Injectors goes with Hp numbers, not PSI. When do people will learn that PSI is just a pressure number. You can't base yourself on PSI for nothing else than your own mind.
find out how many Hp you want to make first then come back.
Gilles
2.3 Ho
Sunday, March 13, 2005 5:33 PM
I would like to run about 175 to 200 hp. I'm pretty sure I need 30 lb, but I'm not sure of which injectors will work.
Monday, March 14, 2005 12:37 AM
You want the right answer for your question... go to this site... fill in the blanks and it will give you a number you need...
Selecting the Proper Injector
Monday, March 14, 2005 3:04 AM
Marren fuel injection calculator
that one work too.
32 lbs injector will be fine for 200Hp.
Gilles
2.3 Ho
Monday, March 14, 2005 6:52 PM
what size are stock 2200 injectors?
Monday, March 14, 2005 6:54 PM
19lbs/hr, 198cc
Monday, March 14, 2005 9:42 PM
im using 310cc injectors and i am at 200whp... if that helps any...
Wednesday, March 16, 2005 4:24 PM
this is what you prolly need...
http://www.carcustoms.net/product_info.php?cPath=265_22_32_593&products_id=398
and dont listen to mfk-223... he just hates it when people ask questions.
