I have a water and oil cooled turbo, was wondering how to hook up the water part. I tap into the huge radiator hose where? And where do I get those parts? Thanks for the help.
"Beer, the cause of, and solution to, all of lifes problems..."
-Homer
My SRT-4
Mopar Stage 2, Mopar BOV, Mopar STS, Booger Bushings, B&B Turbo Back 3" Exhaust, Greddy Turbo Timer, Greddy Profec B Spec 2 EBC, Injen Intake, Rage Wastegate Actuator, Zex Inercooler Sprayer, ES Motor Mount Inserts, $20 Oil Catch Can, MSD Ignition Coil, MSD 8.5mm Ignition wires, NGK Spark Plugs, SRT A/F Ratio Gauge by AutoMeter in a custom pod
I was thinking the same thing. Is there any parts I can specically use or can I just shove in a bolt?
-Homer
My SRT-4
Personally I disagree. Think about the temperatures your turbo will reach. Stop running water through your block, heck it's oil cooled just like your turbo. Right? Yes, hooking up the water lines was a pain, but cooler turbo means less heat soak to intake charge, longer turbo life, lower oil temperatures.....
Matt S.
<a href="http://www.cardomain.com/id/kindofcavy"><img src="http://img61.exs.cx/img61/8537/J-Sig8b.jpg" alt="Image Hosted by ImageShack.us" /> </a>
to save your bushings, it is a great idea to use water. I highly recommend hooking it up, just go to a local parts store, or shop, and get two t's (some people day plastic some say metal) and simply tap into your heater core line.
