Bm shiftplus help ASAP - Transmission Forum
Monday, March 21, 2005 8:10 PM
Ok im odering the BM Shiftplus.
http://www.turbotechracing.com/productcart/pc/viewPrd.asp?idcategory=495&idproduct=1136
is that for my 02 ecotec. I just want to make sure before i buy it. Im wanting to order it ASAP so I just need some people to confirm and ill be on my way to another mod
THanks, alot
Brandon
Re: Bm shiftplus help ASAP
Monday, March 21, 2005 8:15 PM
yeah it will work all ecotec automotics have the 4 speed. So you will have no problems
-Aaron
www.TurboTechRacing.com
Monday, March 21, 2005 8:17 PM
Do you have aim or msn I can contact you. I plan on buying alot of parts from turbotech .
Monday, March 21, 2005 8:26 PM
AOL is TTRAaron
-Aaron
Monday, March 21, 2005 9:51 PM
ive installed several in 03 and 04's , and never had any problems
please refer to this post for pics , the 4t40/4t45 the wires are in the same spot and colors
http://www.j-body.org/forums/read.php?f=41&i=4376&t=4376
also i use heat shrink style butt connectors , i worked for chevrolet , and its their recomended wire repair method , they have a glue inside that seals and makes the connection stronger
i will tell the radiator hose is in the way of getting to the plug on the eco's i use a pry bar to hold it out of the way while i did the installs , also the intake tube is in the way and needs to be removed
