How to tell if your Shift Cables are worn? - Transmission Forum
Saturday, April 23, 2005 9:48 PM
Just wondering on how to tell if your shiftcables or shifter is worn out?
I noticed that my shifter doesn't glide through the gears as smooth as in my friends car (isuzu)
Is it possible that I have a stretch shift cable?
When I shift I usually hear clunks,
what could this be?
thanks,
<a href= "http://www.j-body.org/members/mrsparkle/cars/1/">
<img src= "http://registry.gmenthusiast.com/images/mrsparkle/personal_pic.jpg">
Re: How to tell if your Shift Cables are worn?
Saturday, April 23, 2005 9:54 PM
not sure man, I broke a shift cable on day just drivin normal. I got a almost brand new set that i put in a month before i crashed my car. Im parting it out so if you want em make a resonable offer. They were $125 new from GM. You may have worn cables or youre shifter bushing could be worn.
damn right that says premium biatch!
Saturday, April 23, 2005 9:55 PM
if you had a bad shift cable, you'd very well know it
i hate to be a pesimist... but if you hear clunking, i'd think there are bigger problems than your shift cables
Sunday, April 24, 2005 12:20 AM
yea clunking is BAD. Is it only when you shift? Cause it could be your syncros.
Wednesday, April 27, 2005 10:19 AM
i think i have th same problem he has..
no clunking but 1st for me is hard to get into and it just doesn't glide smoothly when you shift.. not like it used to .
2004 Nissan Maxima SE w/ Elite Pkg
2005 Infiniti G35 Coupe w/ Sport Pkg
Wednesday, April 27, 2005 11:39 AM
My shifts have been hard for about a year.. struggling to get it into gear.. well finally my shifter wore out and i got the B&M shifter from karo. Installed it.. still didnt feel right, it was actually harder to get into gears. it was the cables. one way to see is snap off the cables on the transmission and that little arm with the cables on it should move up and down and side to side easy. you should be able to engage gears and hit neutral and rev, etc.. you can check the cables by popping them off the transmission then go inside the car and move the shifter around. should move freely and without any problems. my cables were actually worn out of the insulation and the insulation was moving on and off the bell housing so it wasnt even hitting the shifts right.
