f23 tranny fluid change - Transmission Forum
Monday, April 18, 2005 4:08 PM
can someone post the steps?
i have never done it before
searched a lil bit couldt find much
just a post about what fluids to use
so if someone could help me out w/ some steps
maybe make it a sticky
Re: f23 tranny fluid change
Sunday, May 01, 2005 2:09 PM
bump
ok at least can someone tell me the recommended fluid?
Sunday, May 01, 2005 2:57 PM
i have liked Mobil1 ATF and now i use amsoil atf both work great with smooth shifting even in cold weather now i have tried royalpurple syncromax and that stuff was hard shifting when the weather got below 30 deg they also say B&M synthetic trick shift is good also
as far as changing it there is a plug on to of the trans that you have to remove the S-tube from your intake to acess it is 8mm allen, and the drain plug in on the drivers side of the trans and it is a 8mm allen also. i put just 2 quarts in mine and she is fine.
see ya!
Monday, May 02, 2005 11:04 AM
good stuff
thanks
