Transmittion swap coming soon! Tell me everything - Transmission Forum
Friday, May 13, 2005 11:49 AM
At the end of the summer i will be swaping out my 3 speed auto trans out of my 96 cavy 2.2 and will be putting in a 2.4 z24 motor and a 5 speed manual trans. Please give me a list of EVERYTHING I need to have as far as mounts, ecu, the whole works for this trans swap be a success!! Thanks.
Re: Transmittion swap coming soon! Tell me everything
Sunday, May 15, 2005 1:31 AM
*2.4 Motor
*2.4L tranny
*Tranny mounts
*bolts for the tranny mounts
*bolts that go through the mounts
*Chassis brackets (need to be MIG or TIG welded)
*Flywheel
*Flywheel to crank bolts
*Pressure plate
*pressure plate to flywheel bolts
*clutch plate
*alignment tool
*slave cylinder
*Both axels
*Complete front wiring harness(different sensors)
*ECM reprogrammed by GM / donor ECM
*Shifter
*shifting cables
*shifting cables bracket
*bolts to mount shifting cable bracket
*clutch pedal
*master cylinder with reservoar and lines
Sunday, May 15, 2005 1:41 PM
Do u know the total cost for everything plus installation? Do u think its worth doing or just go fast in a automatic.
Sunday, May 15, 2005 1:47 PM
Um, really hard to say total cost only because I'm getting everything from the wrecker for practically nothing. Somones else said that to get it done by a shop would be ridiculously expensive. Basically, unless you can do it yourself or have uber coinage then it'd be smarter to trade it in for something already in a Z24 package.
