shiftplus problem - Transmission Forum
shiftplus problem
Monday, May 16, 2005 4:32 AM
Installed it yesterday, everything is hookup up right followed little bills instructions. 10 mins after driving cell came on code P0717 which is input speed sensor circuit low input. My traction light is also on not worried about this. Also the shiftplus is staying in stage 2 even after I shut the car off and shut the shiftplus off it still shifts in stage 2. When I first installed it, it worked normal then after I got home and started the car again everything went wrong.
Re: shiftplus problem
Monday, May 16, 2005 4:41 AM
make sure that the wires are not shorted at the connections and making it stick in stage two.
Monday, May 16, 2005 5:36 AM
heres my hawack at it. basicly if the car reads a weak connection then it's my belif that it will throw it into limp mode. how well are the wires connected and where in the harness did you connect it.
"boobs now with Riboflabin"
