help quick please - Transmission Forum
help quick please
Friday, July 01, 2005 12:59 PM
i am wondering if anyone knows the name of the part that is attatched to the tube that comes down from the area where you put in your clutch fluid and goes into the clutch. it is a black piece about 3 inchs long that is located right under the bleed off valve. i need to know the name because mine is leaking from that part becase the piece behind it will not lock into place. please help ASAP. thanks
Re: help quick please
Friday, July 01, 2005 3:15 PM
that is part of the slave cylinder inside the bell housing you might get lucky and only have to replace an o-ring there but probably not....
