The axle i bought came off of an 05 cavi.Just got to get the abs fixed when i get home.
Ok got the gm axle back from the axle re builder today,and went ahead and installed it.
As you can see the inner boot isn't being stretched,took for a spin and it worked great!.
Thanks for the comments above to help me solve my problem,looks like i'll just rebuild the axles next time instead of buying from Oriellys.
The factory shaft was about 2'' longer so it worked out great.
Good to see you got it worked out.
gtpsunfire wrote:Good to see you got it worked out.
Thanks,I'm glad it wasn't anything worse,it had me worried for awhile.
... why would you buy something important from shucks/oreillys? just like wipeing before you poop. Dosent make a bit of sense
Remember... One test is worth a thousand expert opinions.
