replaced getrag, car won't move - Transmission Forum
Thursday, April 05, 2012 6:17 PM
i inherited a 2001 sunfire, 2.2 with a getrag 5-speed that had a busted shift fork.
picked up a used trans for pretty cheap from a reputable scrap yard. seemed to be in good order, but no previous info is known.
did NOT replace the clutch due to time and money constraints.
got everything in, clutch bled, pressure is good. can hear the throwout bearing move. started the car and it won't move. shifts through all the gears with the engine running, WITHOUT hitting the clutch. i've gotta tear it all out anyways, but just wondered if it sounds like a bad trans or a busted clutch.
___________________________________________________________
2001 Chevy Blazer
4.3L 5 speed manual
Alpine deck, Type R 12in. sub.
145k miles
1997 Pontiac Sunfire
2.2L automatic trans
146k miles
Re: replaced getrag, car won't move
Friday, April 06, 2012 4:38 AM
Sounds like your clutch is bad.
Saturday, April 07, 2012 6:17 AM
i just did the same thing on an 01 z24, pulled transmission back out and turned out splines on transmission were not going into clutch, double check that the transmission actually went into clutch.
