Getrag F23 - That one Bolt you can't get out... - Transmission Forum
Wednesday, April 18, 2012 6:19 AM
How do you get that bolt out in the bellhousing of the F23 (that is behind the plastic cover going into a shaft) without putting heat to it and destroying the bearing there ? Is it Right or Left hand thread ? I have use a 2 1/2 ft breaker bar, hit it with an impact wrench. I don't want to break the gears inside. Need to install an OBX LSD...
Re: Getrag F23 - That one Bolt you can't get out...
Wednesday, April 18, 2012 7:58 AM
I used an impact gun, but it had 600 ft lbs in reverse.
Maybe you need a stronger one?
Its a standard bolt, but it had thread-lock on it.
Wednesday, April 18, 2012 9:54 AM
So, It's Right-Hand Thread ? Mine only goes to 400 ft. lbs.
Wednesday, April 18, 2012 10:05 AM
Yeah its RH.
I had to take mine to my buddies shop, my gun was too weak!
Wednesday, April 18, 2012 10:41 AM
A big breaker bar worked for me. Kinda scary because it's hollow, and it makes a horrible snapping sound when you break it loose, but it will come out. Make sure you clean the threads and reinstall with loctite.
Currently 6th quickest Ecotec on the .org -12.453 @ 116.45 MPH!!!
Wednesday, April 18, 2012 10:46 AM
How did that work out for you?
How did you keep output shaft from spinning?
That was my problem, you spin one, the other one spins.
Wednesday, April 18, 2012 10:56 AM
Yeah used an impact gun on mine as well. to install or remove without air I used an old clutch and fabbed up something to hold it in place.
Wednesday, April 18, 2012 11:15 AM
impact gun and heat.
Wednesday, April 18, 2012 12:28 PM
I used a 3 foot jack handle with a large allen key. Heat Heat Heat Heat. and lots of walking around in circles while my dad kept heat on the bolt!
Wednesday, April 18, 2012 6:19 PM
My buddies at SPEC Clutch are sending me a Clutch Plate Hub to make a tool out of. Just weld a socket on it. That should hold the input shaft still instead of a Pipe Wrench. LOL !!!
Monday, April 23, 2012 10:54 AM
GOOD IDEA.
Make it a quality piece and rent it out.
Im sure you could make at least $20 a pop!
Saturday, April 28, 2012 7:14 AM
Got the Hub tool made. Broke (2) Hex Sockets already. No give on this thing. Guess I'll have to put heat on it and ruin the bearing in the bellhousing to get it out. Any other ideas ?
Saturday, April 28, 2012 7:24 AM
You won't hurt the bearing. We did not hurt mine, and I'm still running it with 136k.
Saturday, May 12, 2012 6:06 AM
strat81 Online
i used my factory clutch and an allen key. put the allen key in the hollow bolt and then put the clutch disc on the input shaft and turned the clutch disc by hand in the correct direction. did the same to tighten the bolt back up... just spun the clutch in the opposite direction.
Thursday, May 17, 2012 12:56 PM
^^ thats exactly what i always do.. i also made a tool like mentioned above. i cut apart a stock clutch to get the spline piece.
Thursday, May 17, 2012 8:45 PM
Any pics of what exactly you guys are working on? I will need to take mine apart when I get it.
Saturday, June 02, 2012 10:36 AM
Just confirming that part # 9120610 is for the black plastic piece
Jason
99 Z24
LG0/LD9 for Life
10 Year Bash Veteren
Saturday, September 01, 2012 5:32 PM
Another idea is to remove shifter and lock the trans in two gears at once. Then use huge breaker bar and have a friend hold the trans down. My trans was brand new and much tighter than any used. The clutch plate tool works good on used trans.
